Output Value with Decimals
Postby bootleg » Thu Jan 04, 2024 4:12 am
Hello,
I wanted to display a certain value from HWinfo - its a voltage reading with decimal points, specifically the "GPU 16-pin HVPWR Voltage" that nvidia graphics cards have. The value is out usually in decimal points.
How do I configure the overlay to show 3 decimal points, its outputting only the value itself - ie 12 instead of 12.123.
Please help.
bootleg
Re: Output Value with Decimals
Postby TheLaGmAn » Thu Jan 04, 2024 1:58 pm
try setting maxdigits to 0 to see if any comma appears, it should display the value as goverlay receives it
Postby bootleg » Sun Jan 07, 2024 3:36 am
TheLaGmAn wrote:try setting maxdigits to 0 to see if any comma appears, it should display the value as goverlay receives it
thanks for the reply. Tried it too and set it to 0, save and apply, still showing as 12
edit: no comma appeared
bootleg
