My 2.8 GOverlay does not work
Postby Scorpion69 » Sat Jan 26, 2019 7:09 pm
So I have both the 2.8 and the 3.5 GOverlay
The drivers show they are all installed correctly
The 3.5 display work fine
The 2.8 give me an all white display, a pale white display, or a black display.
The things I tried:
- Different USB cables
- Different USB ports
- Uninstalled and reinstalled the drivers both automatic and manually
- I uninstalled and reinstalled the GOverlay software.
I really need some help here...
Scorpion69
Re: My 2.8 GOverlay does not work
Postby TheLaGmAn » Mon Jan 28, 2019 1:35 am
This happend out of blue with the 2.8? how long have you had this display?
Postby Scorpion69 » Tue Feb 05, 2019 9:54 pm
I uninstalled everything and tried to reinstall them both...
I did the driver install and the 3.5 works fine...the 2.8 just will not install...it show as "not detected" in yellow
So I tried a manual driver install....that di not work....I am pulling my hair out here
I managed to get it "GREEN" and "ENABLED" BUT....I still have problems with it going to an all "WHITE" screen
Here is a report
So I uninstalled everything GOverlay.......and EVERY file with it.
I did a complete reinstall and well now I am really in trouble....because NOTHING is RECOGNIZED at all....I really messed it up.
Let me know when we might be able to try and fix this...............
report.txt
(5.03 KiB) Downloaded 578 times
Scorpion69
