SpeedFan Plugin (BETA)
Postby TheLaGmAn » Thu Mar 20, 2014 8:55 pm
SpeedFan plugin for GOverlay.
It reads SpeedFan Temperatures (no FAN speeds or Voltages yet).
Let me know if it has issues.
Temperatures are named as "Temperature #X" since SpeedFan does not report the names of the temps, so you will have to check SpeedFan to see which one corresponds to the temperature you want, the order displayed is the same order SpeedFan shows them, so the first temperature is the first temperature shown in SpeedFan options.
Download & Install instructions:
Re: SpeedFan Plugin (BETA)
Postby ppgrainbow » Fri Mar 21, 2014 3:20 am
Thank you so much for developing the SpeedFan plugin! I hope that it will be a part of GOverlay v1.4.2 once it's finished! :)
ppgrainbow
Postby dewasha » Fri Mar 28, 2014 10:07 am
dewasha
Postby JPYZFR1 » Mon Apr 07, 2014 1:23 pm
Postby vabchgent » Mon Apr 14, 2014 10:46 pm
vabchgent
Postby Grahms » Sun Apr 27, 2014 1:46 am
Grahms
Postby Digidreamer » Wed Jun 04, 2014 2:55 pm
Mnay Thanks in Advance..:)
Digidreamer
Postby lexsan » Wed Jun 18, 2014 6:32 pm
get te
lexsan
Postby geemac » Wed Jul 09, 2014 3:56 pm
geemac
Postby kilink » Sat Oct 11, 2014 7:36 pm
kilink
Users browsing this forum: No registered users and 0 guests
