Firmware 231 to 241
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Re: Firmware 231 to 241
Postby carmyyy » Mon Mar 29, 2021 6:46 pm
TheLaGmAn wrote:.
DO NOT UPDATE YOUR FIRMWARE UNLESS THERE IS A FEATURE ON IT THAT YOU NEED.
ONLY UPGRADE YOUR FIRMWARE WHEN ON GOVERLAY 1.6.9.11 OR NEWER
ONLY UPGRADE IF YOU ARE ON 231
Changelog on 241:
- Added feature to be able to turn the device 180 degrees. Works with GOverlay on at least 1.6.9.11
Risks on upgrading firmware:
If the upgrade is stopped half way it can brick the device.
If there is a connection during upgrade it can brick the device.
ONLY UPDATE IF YOU REQUIRE ANY OF THE FEATURES OF THIS UPDATE
Steps to upgrade firmware:
carmyyy
Postby Kingkaktus » Fri Apr 02, 2021 12:24 pm
Kingkaktus
Postby Chinaquads » Sat Apr 03, 2021 9:22 am
TZhanky ou
Chinaquads
Postby Fire19 » Mon Apr 05, 2021 10:23 am
Fire19
Postby Fatherbull » Thu Apr 08, 2021 3:39 pm
thx
Fatherbull
Postby Stube36 » Fri Apr 09, 2021 6:56 am
Can i try this one?
Stube36
Postby Talaock » Fri Apr 09, 2021 9:52 pm
TheLaGmAn wrote:.
Changelog on 241:
Talaock
Postby danielvan92 » Sat Apr 10, 2021 10:22 am
Thx
danielvan92
Postby Magnar » Fri Apr 23, 2021 5:37 pm
ty
Magnar
Postby endcrew » Sat Apr 24, 2021 9:59 am
thx
endcrew
PreviousNext
Return to Firmware Updates
Users browsing this forum: No registered users and 13 guests
