new user - help to inport
Postby partycrash » Tue Mar 12, 2019 5:18 pm
I just received my 3.5 display ..
but can't figure out how to import Gizmo1203 dll's, that I have downloaded and packed zip out
but do not know how to activate the files that were in the file or which folder they must in
partycrash
Re: new user - help to inport
Postby TheLaGmAn » Wed Mar 20, 2019 2:06 pm
The DLL file should be put inside \Plugins\
Just in case, make sure the dll is not blocked by your browser, right click on the file, hit properties, and see if you have an unblock button, if you do, click there.
Then start goverlay (or restart it) and see if the plugin appears in "Plugins", select it and set it to enable.
Then the sensors should appear in your 3.5'' tab.
