GOverlay BETA 1.4.2 - Beta #18
Re: GOverlay BETA 1.4.2 - Beta #18
Postby TheLaGmAn » Fri Oct 17, 2014 1:27 pm
Have you set the correct name for the WhileGaming profile to match the executable file triggering the gaming?
If you are running arma3.exe the profile must be named arma3.exe, otherwise it will show the default gaming profile.
Postby Incolor_Devil » Fri Oct 17, 2014 1:57 pm
Thank you
Incolor_Devil
Postby mfilos » Fri Oct 17, 2014 4:03 pm
TheLaGmAn wrote:Have you set the correct name for the WhileGaming profile to match the executable file triggering the gaming?
Aha! Now I understand how it work, thanks a lot (I thought once you choose it, it becomes default (as on "Windows" mode).
The bad thing is that I don't want to import the profile for every single .exe file I use. Isn't there an easy way to import a profile as the Default Profile "While gaming" ? It would be really annoying having to make the "While gaming" profile same as the "Windows" one by hand :S
I tried importing with "Default Profile" name but I just got a second record (without caps) so I just deleted it to be sure.
mfilos
Postby TheLaGmAn » Fri Oct 17, 2014 6:02 pm
You are right, forgot about that, i will make an option to be able to set it as default on whilegaming
Postby mfilos » Fri Oct 17, 2014 6:13 pm
You rock!!!
mfilos
Postby liveordie » Sat Oct 18, 2014 10:52 am
Thanks you!
liveordie
Postby thejalma » Sat Oct 18, 2014 2:55 pm
Testing :D
thejalma
Postby U ID10T » Sun Oct 19, 2014 1:43 am
Thx u
U ID10T
Postby juratrilobit » Sun Oct 19, 2014 5:35 am
Thanks you.
juratrilobit
Postby jase » Wed Oct 22, 2014 6:44 pm
jase
PreviousNext
