Version 1.4.1.15 (BETA 1.4.2):
- Fixed a bug on which after using the search to find sensors the "LCDSysInfo Specials" was missing from the list
- New Feature: You can now export and import profiles on the OnWindows tab (Remember that images have to be manually copied if you modified them).
Please let me know if anyone is having issues with the plugins not appearing at all, i have yet to find a solution but since i cant reproduce it myself i cant fix it until i get more info.
Please refer to new BETA: viewtopic.php?f=3&t=55
