Weather provider
Re: Weather provider
Postby JPYZFR1 » Sat Jan 14, 2017 8:26 pm
14-Jan-17 22:18:21:WeatherPull (Global) - pireas,gr : Exception thrown: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: startIndex
14-Jan-17 22:18:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 22:18:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 22:18:15:WeatherPull (Global) - Getting weather info
14-Jan-17 21:48:16:WeatherPull (Global) - Temperature is: 12 (12/39)
14-Jan-17 21:48:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 21:48:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 21:48:15:WeatherPull (Global) - Getting weather info
14-Jan-17 21:18:21:WeatherPull (Global) - pireas,gr : Exception thrown: Index was out of range. Must be non-negative and less than the size of the collection.
14-Jan-17 21:18:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 21:18:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 21:18:15:WeatherPull (Global) - Getting weather info
14-Jan-17 20:48:29:WeatherPull (Global) - pireas,gr : Exception thrown: Index was out of range. Must be non-negative and less than the size of the collection.
14-Jan-17 20:48:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 20:48:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 20:48:15:WeatherPull (Global) - Getting weather info
14-Jan-17 20:18:16:WeatherPull (Global) - Temperature is: 13 (13/39)
14-Jan-17 20:18:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 20:18:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 20:18:15:WeatherPull (Global) - Getting weather info
14-Jan-17 19:48:33:WeatherPull (Global) - Temperature is: 13 (13/39)
14-Jan-17 19:48:32:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 19:48:32:WeatherPull (Global) - City >pireas,gr< found as 959973
14-Jan-17 19:48:32:OHMD inited
14-Jan-17 19:48:32:Weather request goes to: http://query.yahooapis.com/v1/public/yq ... reas,gr%22
14-Jan-17 19:48:32:WeatherPull (Global) - pireas,gr has no WOEID, getting one
14-Jan-17 19:48:32:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 19:48:32:WeatherPull (Global) - Getting weather info
14-Jan-17 19:48:32:Calling WeatherPull
At 20:48:15 it stopped working.
At 21:48:16 it's ok
At 22:18:21 it stopped working again.
My suggestion for the icons is:
for clear, sunny,mostly sunny,mostly clear ................................................. use sunny icon
for partly sunny,partly cloudy,.................................................................use cloudy icon
for showers,rain,light rain,heavy rain....................................................... use rain icon
for cloudy,fog,overcast................................................................ .......use overcast icon
for mostly cloudy................................................................................use mcloudy icon
for snow,light snow, heavy snow ..............................................................use snow icon
for t-storm.......................................................................................use storm icon
The temperature is ok.
Postby TheLaGmAn » Sat Jan 14, 2017 10:32 pm
About the stop/start working i think i found the issue.
About the icons, there are a lot more than those. Also there is no "partly sunny" in the codes, add the suggestions of the ones you want to modify after the last .............. ,only for those you want to modify
0 tornado..............................storm................
1 tropical storm.......................storm................
2 hurricane............................storm................
3 severe thunderstorms.................storm................
4 thunderstorms........................storm................
5 mixed rain and snow..................rain.................
6 mixed rain and sleet.................rain.................
7 mixed snow and sleet.................rain.................
8 freezing drizzle.....................rain.................
9 drizzle..............................rain.................
10 freezing rain.......................rain.................
11 showers.............................rain.................
12 showers.............................rain.................
13 snow flurries.......................snow.................
14 light snow showers..................snow.................
15 blowing snow........................snow.................
16 snow................................snow.................
17 hail................................overcast.............
18 sleet...............................overcast.............
19 dust................................overcast.............
20 foggy...............................overcast.............
21 haze................................overcast   ..........
22 smoky...............................overcast.............
23 blustery............................overcast.............
24 windy...............................overcast.............
25 cold................................mcloudy..............
26 cloudy..............................mcloudy..............
27 mostly cloudy (night)...............mcloudy..............
28 mostly cloudy (day).................mcloudy..............
29 partly cloudy (night)...............cloudy...............
30 partly cloudy (day)   ..............cloudy...............
31 clear (night).......................overcast.............
32 sunny...............................clear................
33 fair (night)........................clear................
34 fair (day)..........................clear................
35 mixed rain and hai..................rain.................
36 hot.................................clear................
37 isolated thunderstorms..............storm................
38 scattered thunderstorms.............storm................
39 scattered thunderstorm..............storm................
40 scattered showers...................storm................
41 heavy snow   .......................snow.................
42 scattered snow showers..............snow.................
43 heavy snow..........................snow.................
44 partly cloudy.......................cloudy...............
45 thundershowers......................rain.................
46 snow showers........................snow.................
47 isolated thundershowers.............rain.................
Postby JPYZFR1 » Sun Jan 15, 2017 9:19 am
The only change is:
31 clear (night).......................overcast............. (overcast change to clear)
Postby TheLaGmAn » Sun Jan 15, 2017 6:02 pm
Okay, i will add that change then
Postby JPYZFR1 » Mon Jan 16, 2017 5:01 pm
40 scattered showers...................storm................(Storm change to rain)
They are too many and i couldn't see it.
I've checked them twice and after these changes they will be ok.
Thanks for your time.
Postby JPYZFR1 » Tue Jan 24, 2017 8:18 pm
24-Jan-17 23:11:26:WeatherPull (Global) - Thread ended
24-Jan-17 23:11:26:WeatherPull (Global) - Temperature is: 8 (8/36)
24-Jan-17 23:11:25:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
24-Jan-17 23:11:25:WeatherPull (Global) - investigating: pireas,gr
24-Jan-17 23:11:25:WeatherPull (Global) - Getting weather info
24-Jan-17 22:41:27:WeatherPull (Global) - Thread ended
24-Jan-17 22:41:26:WeatherPull (Global) - Temperature is: 0 (0/32)
24-Jan-17 22:41:25:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
24-Jan-17 22:41:25:WeatherPull (Global) - investigating: pireas,gr
24-Jan-17 22:41:25:WeatherPull (Global) - Getting weather info
24-Jan-17 22:11:31:WeatherPull (Global) - Thread ended
24-Jan-17 22:11:31:WeatherPull (Global) - Temperature is: 0 (0/32)
24-Jan-17 22:11:25:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
24-Jan-17 22:11:25:WeatherPull (Global) - investigating: pireas,gr
24-Jan-17 22:11:25:WeatherPull (Global) - Getting weather info
24-Jan-17 21:41:31:WeatherPull (Global) - Thread ended
24-Jan-17 21:41:31:WeatherPull (Global) - Temperature is: 0 (0/32)
24-Jan-17 21:41:25:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
24-Jan-17 21:41:25:WeatherPull (Global) - investigating: pireas,gr
24-Jan-17 21:41:25:WeatherPull (Global) - Getting weather info
24-Jan-17 21:11:30:WeatherPull (Global) - Thread ended
24-Jan-17 21:11:30:WeatherPull (Global) - Temperature is: 9 (9/37)
24-Jan-17 21:11:29:Version detected 1.4.5 is the same as 1.4.5 - No need to update
24-Jan-17 21:11:29:Latest version received as: GOverlay_v145.zip (1.4.5)
24-Jan-17 21:11:29:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
24-Jan-17 21:11:29:WeatherPull (Global) - City >pireas,gr< found as 959973
24-Jan-17 21:11:29:OHMD inited
24-Jan-17 21:11:29:WeatherPull (Global) - pireas,gr has no WOEID, getting one
24-Jan-17 21:11:29:WeatherPull (Global) - investigating: pireas,gr
24-Jan-17 21:11:29:WeatherPull (Global) - Getting weather info
24-Jan-17 21:11:29:Calling WeatherPull
Same issue again.... :?
Postby TheLaGmAn » Tue Jan 24, 2017 9:51 pm
which one is the issue specifically? losing the weather value (setting to zero) ?
Postby JPYZFR1 » Wed Jan 25, 2017 7:19 am
Yes, The temperature is 0.
Postby TheLaGmAn » Wed Jan 25, 2017 1:37 pm
Okay, the issue is that sometimes yahoo returns nothing, i will add a couple of retries when there is no return to try to solve the issue
Postby TheLaGmAn » Wed Jan 25, 2017 10:17 pm
I just uploaded 1.4.6, try to update from within GOverlay and see if it works better now
PreviousNext
Users browsing this forum: No registered users and 30 guests
