Weather provider
Re: Weather provider
Postby JPYZFR1 » Tue May 03, 2016 5:44 pm
Pireas,attica,gr
Unit has 7 icons....
for clear, sunny,mostly sunny,mostly clear ................................................. use sunny icon
for partly sunny,partly cloudy,.................................................................use cloudy icon
for showers,rain,light rain,heavy rain....................................................... use rain icon
for cloudy,fog,overcast................................................................ .......use overcast icon
for mostly cloudy................................................................................use mcloudy icon
for snow,light snow, heavy snow ..............................................................use snow icon
for t-storm.......................................................................................use storm icon
Postby JPYZFR1 » Mon May 16, 2016 8:34 pm
for clear, sunny,mostly sunny,mostly clear ................................................. use sunny icon (297.1)
for partly sunny,partly cloudy,.................................................................use cloudy icon (295.1)
for showers,rain,light rain,heavy rain....................................................... use rain icon (299.1)
for cloudy,fog,overcast................................................................ .......use overcast icon (298.1)
for mostly cloudy................................................................................use mcloudy icon (296.1)
for snow,light snow, heavy snow ..............................................................use snow icon (300.1)
for t-storm.......................................................................................use storm icon (301.1)
Only mcloudy icon matches with yahoo weather condition. All the others are misplaced.
These are my suggestions for which icons should be displayed on unit according to yahoo weather conditions.
As far as the unit is concerned,the fact that it displays an overcast icon instead of a sunny icon is irrelevant to icons' accuracy. The problem is that the icons don't match with yahoo weather conditions.
A new match between my suggestions and the icons that the unit displays would solve the problem.
Postby TheLaGmAn » Wed May 18, 2016 12:49 am
Sorry for the delay.
I understand some icons might not be totally accurate but those should be showing correctly under their range.
Can you see this page
https://query.yahooapis.com/v1/public/y ... eswithkeys
And check if the weather is the same as the one you want?
Because from there goverlay is getting your weather
Right now its "clear"
<yweather:condition code="31" date="Wed, 18 May 2016 02:00 AM EEST" temp="66" text="Clear"/>
Postby JPYZFR1 » Wed May 18, 2016 9:19 pm
http://s32.postimg.org/8ij0ngj7p/goverlay.jpg
There are two problems.
1. the page (https://query.yahooapis.com/v1/public/y ... eswithkeys) takes data with delay.
2. <yweather:condition code="31" date="Wed, 18 May 2016 11:00 PM EEST" temp="69" text="Clear"/> and unit shows overcast icon.
In this case:
http://s32.postimg.org/ptxny41vp/Untitled1.jpg
The time is: <lastBuildDate>Thu, 19 May 2016 12:48 AM EEST</lastBuildDate>
and unit show the weather when time was <yweather:condition code="31" date="Wed, 18 May 2016 11:00 PM EEST" temp="69" text="Clear"/>
There is a delay of 1hour and 48 minutes.
The unit shows overcast icon.
Refreshing again ...
http://s32.postimg.org/mui2qf72d/Untitled2.jpg
One hour delay.
Postby TheLaGmAn » Fri May 27, 2016 6:12 pm
i have not forgotten you, im doing some important changes on GOverlay so i can not give you a fix right now but i will look into it.
Postby JPYZFR1 » Sat May 28, 2016 7:07 am
Thank you my friend,I appreciate your work on it.
Postby JPYZFR1 » Sat Dec 10, 2016 9:56 pm
Hi. I think that you forgotten me... 7 months passed.
Postby TheLaGmAn » Sat Dec 10, 2016 10:22 pm
I have no forgotten you but i know 7 months sound unnaceptable.
I have been waiting on the manufaturer because some changes are coming but its been delay after delay trying to work some things out.
I will be releasing a new version soon which includes some changes in the weather system, after i do, we can take a look and see how its performing for you and if it needs any change
Postby JPYZFR1 » Sat Jan 14, 2017 7:28 pm
Thanks my friend.
The problem with icons still exist. When weather condition is clear the device shows overcast icon
14-Jan-17 21:48:16:WeatherPull (Global) - Temperature is: 12 (12/39)
14-Jan-17 21:48:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 21:48:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 21:48:15:WeatherPull (Global) - Getting weather info
14-Jan-17 21:18:21:WeatherPull (Global) - pireas,gr : Exception thrown: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: startIndex
14-Jan-17 21:18:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 21:18:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 21:18:15:WeatherPull (Global) - Getting weather info
14-Jan-17 20:48:29:WeatherPull (Global) - pireas,gr : Exception thrown: Index was out of range. Must be non-negative and less than the size of the collection.
14-Jan-17 20:48:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 20:48:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 20:48:15:WeatherPull (Global) - Getting weather info
14-Jan-17 20:18:16:WeatherPull (Global) - Temperature is: 13 (13/39)
14-Jan-17 20:18:15:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 20:18:15:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 20:18:15:WeatherPull (Global) - Getting weather info
14-Jan-17 19:48:33:WeatherPull (Global) - Temperature is: 13 (13/39)
14-Jan-17 19:48:32:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
14-Jan-17 19:48:32:WeatherPull (Global) - City >pireas,gr< found as 959973
14-Jan-17 19:48:32:OHMD inited
14-Jan-17 19:48:32:Weather request goes to: http://query.yahooapis.com/v1/public/yq ... reas,gr%22
14-Jan-17 19:48:32:WeatherPull (Global) - pireas,gr has no WOEID, getting one
14-Jan-17 19:48:32:WeatherPull (Global) - investigating: pireas,gr
14-Jan-17 19:48:32:WeatherPull (Global) - Getting weather info
14-Jan-17 19:48:32:Calling WeatherPull
At 20:48:15 it stopped working.
At 21:48:16 it's ok
Postby TheLaGmAn » Sat Jan 14, 2017 8:09 pm
Okay, so the temperature number now works correctly?
About the icons, this is the set im using (the number in codeTable represents what yahoo has as a weather code):
https://query.yahooapis.com/v1/public/y ... %20(959973)&format=xml
codeTable("0") = "storm"
codeTable("1") = "storm"
codeTable("2") = "storm"
codeTable("3") = "storm"
codeTable("4") = "storm"
codeTable("5") = "rain"
codeTable("6") = "rain"
codeTable("7") = "rain"
codeTable("8") = "rain"
codeTable("9") = "rain"
codeTable("10") = "rain"
codeTable("11") = "rain"
codeTable("12") = "rain"
codeTable("13") = "snow"
codeTable("14") = "snow"
codeTable("15") = "snow"
codeTable("16") = "snow"
codeTable("17") = "overcast"
codeTable("18") = "overcast"
codeTable("19") = "overcast"
codeTable("20") = "overcast"
codeTable("21") = "overcast"
codeTable("22") = "overcast"
codeTable("23") = "overcast"
codeTable("24") = "overcast"
codeTable("25") = "mcloudy"
codeTable("26") = "mcloudy"
codeTable("27") = "mcloudy"
codeTable("28") = "mcloudy"
codeTable("29") = "cloudy"
codeTable("30") = "cloudy"
codeTable("31") = "overcast"
codeTable("32") = "clear"
codeTable("33") = "clear"
codeTable("34") = "clear"
codeTable("35") = "rain"
codeTable("36") = "clear"
codeTable("37") = "storm"
codeTable("38") = "storm"
codeTable("39") = "storm"
codeTable("40") = "storm"
codeTable("41") = "snow"
codeTable("42") = "snow"
codeTable("43") = "snow"
codeTable("44") = "cloudy"
codeTable("45") = "rain"
codeTable("46") = "snow"
codeTable("47") = "rain"
codeTable("3200") = "clear"
the device icons are
LCDSys_ICO("weather_cloudy") = 295
LCDSys_ICO("weather_mcloudy") = 296
LCDSys_ICO("weather_clear") = 297
LCDSys_ICO("weather_overcast") = 298
LCDSys_ICO("weather_rain") = 299
LCDSys_ICO("weather_snow") = 300
LCDSys_ICO("weather_storm") = 301
this are the yahoo codes
0 tornado
1 tropical storm
2 hurricane
3 severe thunderstorms
4 thunderstorms
5 mixed rain and snow
6 mixed rain and sleet
7 mixed snow and sleet
8 freezing drizzle
9 drizzle
10 freezing rain
11 showers
12 showers
13 snow flurries
14 light snow showers
15 blowing snow
16 snow
17 hail
18 sleet
19 dust
20 foggy
21 haze
22 smoky
23 blustery
24 windy
25 cold
26 cloudy
27 mostly cloudy (night)
28 mostly cloudy (day)
29 partly cloudy (night)
30 partly cloudy (day)
31 clear (night)
32 sunny
33 fair (night)
34 fair (day)
35 mixed rain and hail
36 hot
37 isolated thunderstorms
38 scattered thunderstorms
39 scattered thunderstorms
40 scattered showers
41 heavy snow
42 scattered snow showers
43 heavy snow
44 partly cloudy
45 thundershowers
46 snow showers
47 isolated thundershowers
whats your proposition for the icons?
PreviousNext
