Weather provider
Re: Weather provider
Postby JPYZFR1 » Wed Jan 27, 2016 6:07 pm
27-Jan-16 20:03:14:Calling WeatherPull
27-Jan-16 20:03:14:WeatherPull - Getting weather info
27-Jan-16 20:03:14:WeatherPull - investigating: pireas,greece
27-Jan-16 20:03:14:WeatherPull - pireas,greece has no WOEID, getting one
27-Jan-16 20:03:14:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
27-Jan-16 20:03:14:Check Also Device FW Update: 21799805521914110238-117
27-Jan-16 20:03:14:Adding power mod events
27-Jan-16 20:03:14:GOverlay successfully inited
27-Jan-16 20:05:28:Plugins - Checking: C:\Users\JP\Desktop\GOverlay_v14210_ddf\Plugins\APCUPS.dll
27-Jan-16 20:05:28:Plugin found: C:\Users\JP\Desktop\GOverlay_v14210_ddf\Plugins\APCUPS.dll: GOverlayPlugin.APCUPS.Class1
27-Jan-16 20:05:28:PluginServices - Error loading plugins: Object reference not set to an instance of an object.
27-Jan-16 20:05:28:Plugins - Checking: C:\Users\JP\Desktop\GOverlay_v14210_ddf\Plugins\Aquasuite.dll
27-Jan-16 20:05:28:Plugin found: C:\Users\JP\Desktop\GOverlay_v14210_ddf\Plugins\Aquasuite.dll: GOverlayPlugin.Aquasuite.Class1
27-Jan-16 20:05:28:Plugin Name: Aquasuite for display: lcdsys
27-Jan-16 20:05:28:plugin has option: xmlfile
27-Jan-16 20:05:32:Check Also Device FW Update: 21799805521914110238-117
27-Jan-16 20:05:32:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
27-Jan-16 20:05:32:WeatherPull - 959973 has no WOEID, getting one
27-Jan-16 20:05:32:WeatherPull - investigating: 959973
27-Jan-16 20:05:32:WeatherPull - Getting weather info
27-Jan-16 20:05:32:Calling WeatherPull
27-Jan-16 20:05:31:LCDSys - Screen clear requested and done
Still nothing.....
Postby TheLaGmAn » Thu Jan 28, 2016 3:54 pm
My bad, posted the wrong version
download this one (you only need the .exe)
http://www.goverlay.com/UserFiles/GOver ... 10_ddx.zip
Postby JPYZFR1 » Thu Jan 28, 2016 6:54 pm
YES!!!!! :D :!: :!: :!: :!:
It's working again.
Thank you very much.
Postby robb » Sat Jan 30, 2016 10:39 am
Thanks just noticed my weather wasn't working downloaded the update and now it is
Postby JPYZFR1 » Tue Apr 12, 2016 6:33 pm
12/4/2016 21:29:03:WeatherPull - piraeus,greece : Exception thrown: startIndex cannot be larger than length of string.
Parameter name: startIndex
12/4/2016 21:29:03:WeatherPull - piraeus,greece : Fetching temperatures
12/4/2016 21:29:03:WeatherPull - City >piraeus,greece< found as 959973
12/4/2016 21:29:02:Version detected 1.4.2.10 is the same as 1.4.2 - No need to update
12/4/2016 21:29:02:Latest version received as: GOverlay_v142.zip (1.4.2)
12/4/2016 21:29:02:Weather request goes to: http://query.yahooapis.com/v1/public/yq ... ,greece%22
12/4/2016 21:29:02:WeatherPull - piraeus,greece has no WOEID, getting one
12/4/2016 21:29:02:WeatherPull - investigating: piraeus,greece
12/4/2016 21:29:02:WeatherPull - Getting weather info
12/4/2016 21:29:02:Calling WeatherPull
It seems that stopped working again and showing 0
Postby TheLaGmAn » Wed Apr 13, 2016 2:38 pm
download the newest beta
viewtopic.php?f=3&t=158&p=1042#p1042
Yahoo keeps changing the API, this one should work now (lets hope they dont change it again)
Postby JPYZFR1 » Tue Apr 26, 2016 6:25 pm
Ok. It's working again but icons are wrong!
Yahoo weather website shows clear but GOverlay shows cloudy
http://s32.postimg.org/w5j9602rp/20160426_211113.jpg
http://s32.postimg.org/8axetmg3p/yahoo_weather.jpg
Postby JPYZFR1 » Tue May 03, 2016 4:44 pm
Temperature is OK.
Yahoo weather website shows showers but GOverlay shows T-storms.
http://s32.postimg.org/6zvoknzmt/yahoo_showers.jpg
http://s32.postimg.org/8y48bp0dh/20160503_193304.jpg
Postby JPYZFR1 » Tue May 03, 2016 5:26 pm
Temperature is OK.
Yahoo weather website shows mostly cloudy but GOverlay shows rain.
http://s32.postimg.org/a3pee3q91/yahoo_mostly_cloudy.jpg
http://s32.postimg.org/jcb1ar1d1/20160503_201543.jpg
Postby TheLaGmAn » Tue May 03, 2016 5:36 pm
Can you post your weather setting (to see the exact text of the city you have in the notification weather city text) ?
The icons on the unit are limited tho, there are around 5, so its not 100% accurate since there isnt an icon for showers, other for rain, other for heavy rain, etc.
PreviousNext
Users browsing this forum: No registered users and 13 guests
