by TheLaGmAn » Mon Aug 03, 2015 7:23 pm
Now i get what you are trying to do.
The notification adds blank icons in that spot to clear out any old render and render the new icon in place again (this happens for everything there, including bar graphs, hdd usage, skype icons, etc).
So if you add something on top of the notification bar on the right-edge spot, it will get overwrited by a blank icon every time the screen renders and then the actual icon that would be there (a bargraph for ex, or stay blank if the bar graph is disabled).
Since the notification bar works like that, the alternative is to either re-create a notification bar yourself (by making a plugin) or adding the data you want more to the left, almost next to the weather icon, because the reserved blank icons that get respawned are using 8 slots (each slot is the space of a bargraph on the notification bar).
This has nothing to do with the cables or your device, its a software design on how the notification works because it was never inteded to be used with something on top. The only solution would be to have something on top re-drawing itself every time, because when it doesnt draw it to avoid an innecesary draw on the device (this is what the cache is for), the notification bar does draw on top.
