Dimm Temps not being picked up in HWinfo
Re: Dimm Temps not being picked up in HWinfo
Postby Mage_Mors » Fri Aug 16, 2019 11:33 pm
I figured out how to get beta.. 1.6.6.4
it got worse in the fact that it doesn't fill with zeros now when it doesn't see a value for hwinfo.
hwinfo does update it'self with the dimm values it's seeing and I can watch their graph go up and down based on temps. goverlay seems to have some issue reading HW.DIMM[0] - [3] Temperatures
Mage_Mors
Postby Waster » Wed Oct 16, 2019 10:20 pm
Hi there,
I'm in the same situation, DIMM sensor values from HWinfo64 are ignored by GOverlay, while OK in HWinfo64 window or log file.
In my case, it's DIMM[0] and DIMM[2].
If someone has a solution, let me know.
Waster
Postby TheLaGmAn » Mon Nov 11, 2019 12:36 am
it only happens with the dimm values?
Postby chrimen » Tue Dec 03, 2019 5:55 pm
So far it only happens with the Dimm temperature values.
chrimen
Postby chrimen » Tue Apr 28, 2020 4:16 am
The temps for the dimms are still not showing when using HWInfo.
HWInfo displays the temperature. I use the same sensor in GoOverlay but the values are always 0 in GoOverlay
Is there a fix for this?
All help appreciated.
chrimen
Postby Holzwurm81 » Wed Jun 16, 2021 7:40 pm
I have thesame issue here.
Dimm Temps are not shown in Goverlay but in RTSS, HWinfo etc.
All other Stuff is working like I like but only these Dimm Temps not.
I use the registred Version of HWinfo to read out the Asus Crosshair VII Impact Sensors and latest Goverlay (non beta) Version.
I also tried to rename the Sensor in HwInfo from Dimm [0] Temperature to Dim1 Temp for example.
Since that I have 4 instead of 2 Dimms I get listet through the Plugin in Goverlay but all 4 do not work.
Any Idea how to fix it ? Is there a solution?
Update: I installed the latest RC4 and it is better than before. Now I get at least the 0 Displayed and the "C i added. Before nothing was shown at all.
Markus
Holzwurm81
Postby theanalyzer » Sun Jun 20, 2021 1:44 pm
Same issue, value is blank
using Crucial Ballistix Gaming
theanalyzer
Postby Holzwurm81 » Tue Dec 21, 2021 6:40 pm
Hey, is there any Update on this Issue ?
Still not working :(
thy Markus
Holzwurm81
Postby theanalyzer » Sun Jan 16, 2022 9:55 pm
Usinng 1.6.9.19, with hwinfo32 7.16-4650
Adding sensors for my four DIMMS, it gives a zero reading with the following error:
17-Jan-22 8:54:10 AM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature (P0 CHANNEL A/DIMM 0):°C
17-Jan-22 8:54:10 AM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature (P0 CHANNEL B/DIMM 0):°C
17-Jan-22 8:54:10 AM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature (P0 CHANNEL A/DIMM 1):°C
17-Jan-22 8:54:10 AM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature (P0 CHANNEL B/DIMM 1):°C
That "5af50dea1fe71ae2b6323ba88efdab72" is the same from the 2019 post on page 1 :(
theanalyzer
