goverlay closes randomly after a while
Re: goverlay closes randomly after a while
Postby comfarol » Sat Jun 22, 2019 12:28 am
It's turned off again it happened while i was asleep so not sure on the time. Can't see anything that could be related in event viewer.
comfarol
Postby TheLaGmAn » Sat Jun 22, 2019 5:48 pm
can you test if without any display connected it still crashes?
Postby comfarol » Fri Jul 05, 2019 8:10 am
Just unplugging the device will be enough? Not my monitors right. Unplugging now might take a bit as usual.
comfarol
Postby comfarol » Sat Jul 13, 2019 2:39 am
TheLaGmAn wrote:can you test if without any display connected it still crashes?
Yep, it still closed, screen unplugged.
comfarol
Postby TheLaGmAn » Fri Jul 26, 2019 10:06 pm
okay thats very strange then, because goverlay would not be doing much without displays.
try to disable both displays in
lcdsysinfo2.8 > settings > enabled (to disabled).
Same on 3.5
configuration > goverlay vr and output to disabled.
see if it crashes then. if it does. further disable all plugins.
if it still crashes, do you have aida64, openhwm, siv, teamspeak, skype or mumble on your computer when it crashes?
Postby comfarol » Sat Jul 27, 2019 8:31 am
Of all those I have aida64. I have just reformatted for a other issue that i had come up with the computer. Setting it back up now, will see if that has a change.
also viewtopic.php?f=3&t=724 works on w10 64 1903. Nice and convenient :D
comfarol
Postby comfarol » Thu Aug 08, 2019 8:46 pm
Still closes, only have HWiNFO. I will try the disable 2.8/3.5 thing. The 3.5 panel is auto enabling when I try disable.
comfarol
Postby TheLaGmAn » Thu Aug 08, 2019 11:16 pm
try to disconnect both 2.8 and 3.5 and see if w/o those it still crashes
Postby comfarol » Fri Aug 09, 2019 5:59 am
TheLaGmAn wrote:try to disconnect both 2.8 and 3.5 and see if w/o those it still crashes
Where do i go to disconnect them in the software, cant seem to find it.
comfarol
Postby TheLaGmAn » Fri Aug 09, 2019 1:14 pm
i mean usb disconnect it
PreviousNext
