having issue in log
having issue in log
Postby Mage_Mors » Sun May 19, 2019 9:53 am
I have a new system and it is having issues it says with APP:Disc_Read_C and also APP:Disc_Write_C.
How can I fix this? I am running 2 Samsung 970 Pro nvme drives in Raid 0 and it seems to not be picking up read and write activity.
Thanks for your help.. I have always loved the product but this is the first time with the 3.5 inch version. Plus my scripting works in the scripting engine but not in the product configuration.
Mage_Mors
Re: having issue in log
Postby TheLaGmAn » Sun May 19, 2019 3:20 pm
Is there any message on the logs?
Postby Mage_Mors » Sun May 19, 2019 9:13 pm
Here is what it sees in the logs.
5/19/2019 2:01:21 PM:LCDSysInfo - Error opening device
5/19/2019 2:01:21 PM:Loading charts
5/19/2019 2:01:21 PM:GOverlay successfully inited
5/19/2019 2:11:35 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at GOverlay.Form1.DoPreRender(IntPtr hWnd, String textFormat, Int32 action)
5/19/2019 2:11:35 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:35 PM:LCDSysInfo - Init
5/19/2019 2:11:35 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:36 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:36 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:36 PM:LCDSysInfo - Init
5/19/2019 2:11:36 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:37 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:37 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:37 PM:LCDSysInfo - Init
5/19/2019 2:11:37 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:38 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:38 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:38 PM:LCDSysInfo - Init
5/19/2019 2:11:38 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:39 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:39 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:39 PM:LCDSysInfo - Init
5/19/2019 2:11:39 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:40 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:40 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:40 PM:LCDSysInfo - Init
5/19/2019 2:11:40 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:41 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:41 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:41 PM:LCDSysInfo - Init
5/19/2019 2:11:41 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:42 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:42 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:42 PM:LCDSysInfo - Init
5/19/2019 2:11:42 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:43 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:43 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:43 PM:LCDSysInfo - Init
5/19/2019 2:11:43 PM:LCDSysInfo - Error opening device
5/19/2019 2:11:44 PM:Error in DiskStats! for [APP:disk_write_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:44 PM:Error in DiskStats! for [APP:disk_read_C:] -> Cannot load Counter Name data because an invalid index '' was read from the registry. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
5/19/2019 2:11:44 PM:LCDSysInfo - Init
5/19/2019 2:11:44 PM:LCDSysInfo - Error opening device
Mage_Mors
Postby TheLaGmAn » Mon May 20, 2019 1:33 pm
Okay, lets try a couple of things:
1- Is GOverlay running as admin?
2- Have you hit SAVE after adding the sensor?
3- Can you try restarting GOverlay with the sensor added?
Postby Mage_Mors » Mon May 20, 2019 6:52 pm
1- Is GOverlay running as admin? -- Yes see screenshot
2- Have you hit SAVE after adding the sensor? - Yes the profile has a disk activity icon with those 2 sensors selected and it is saved and loaded every time the system starts up.
3- Can you try restarting GOverlay with the sensor added? Yes - I restarted goverlay several times trying to troubleshoot this thinking it might be cache issue. I also uninstalled and re-installed hwinfo completely several times since it mentioned registry. I don't think it's hwinfo as I can see it is updating when I open that without errors.
Every poll it shows this in log as issue. This attribute is a Raid 0 Volume and it shows correctly in hwinfo.
my permissions
Mage_Mors
Postby TheLaGmAn » Mon May 20, 2019 7:13 pm
i think it might be a windows issue.
open a command prompt in admin and write
lodctr /r
Postby Mage_Mors » Tue May 21, 2019 5:11 am
Error: Unable to rebuild performance counter setting from system backup store, error code is 5
looks like it. hmm fresh install of windows 10 pro
Mage_Mors
Postby Mage_Mors » Tue May 21, 2019 7:42 am
ok you lead me to water :)
I did manage to reset the performance counters once I launched cmd in admin. It said rebuild successful.
I was getting consistent initialization errors so I exported my profiles and completely reset goverlay to factory.
I errors stopped so I imported my profiles and it works perfect. even my scripts work well.
Thanks a bunch for helping.
All of this seems fixed now once I reset the goverlay display.
Mage_Mors
Postby TheLaGmAn » Tue May 21, 2019 1:26 pm
glad you got it working.
Yes, its a common windows issue and goverlay uses that part of windows to get the disk sensors
