Update for grafik flickering
Postby Giveatry » Sat Mar 16, 2019 10:54 pm
Can we hope for an update that fixes the flicker? It's very annoying because it restricts the individual configuration of the display for me.
Giveatry
Re: Update for grafik flickering
Postby TheLaGmAn » Wed Mar 20, 2019 2:04 pm
You mean for the plot graph or what type of flickering?
If you are using a background image, flickering cant be avoided, the display does not have double buffering (hardware) so its not possible to render an image on top of a different one without redrawing, you can make it happen less often by splitting images into parts or keeping a static color behind whats going to change
Postby Giveatry » Thu Mar 21, 2019 5:04 pm
TheLaGmAn wrote:You mean for the plot graph or what type of flickering?
Yes, the flickering when i enable in the Plot Graph the Show sensor value
btw. Is there any way to add a % sign?
Giveatry
Users browsing this forum: Google [Bot] and 8 guests
