Help Please Not Detected.......
Re: Help Please Not Detected.......
Postby ajpowell » Fri Jan 11, 2019 7:58 pm
ajpowell wrote:
TheLaGmAn wrote:What device do you have, the 2.8'' or 3.5'' ?
3.5
support has been great and fixed the problem within moments great service !!!
ajpowell
Postby Honnes » Fri Mar 08, 2019 11:50 pm
Does this work over under Windows 10? Have tried everything now. I have the 3.5 inch device. But my Windows does not recognize the display. What could be the problem?
Honnes
Postby TheLaGmAn » Sat Mar 09, 2019 2:25 pm
It does work on windows 10.
Does your device show up in the device manager?
Have you tried the installer from within the application?
Postby Honnes » Sat Mar 09, 2019 2:47 pm
no it is not displayed in the Device Manager. I already tried everything :-(
*Update
Now I have managed that the device is displayed in Device Manager. But the software still does not recognize it
Honnes
Postby TheLaGmAn » Sat Mar 09, 2019 4:16 pm
does the device turns on? backlight, any text on it?
Have you tried different port / different cable?
Postby Honnes » Sat Mar 09, 2019 4:17 pm
On the Display: Run GOverlay to configuration
Honnes
Postby TheLaGmAn » Sat Mar 09, 2019 4:43 pm
What was the problem the device was not showing up in the device manager?
Try to run the GOverlay Tester
http://goverlay.com/UserFiles/GOverlay/ ... er_v05.zip
Postby Honnes » Sat Mar 09, 2019 4:50 pm
apparently a wobbler on the usb socket
The report:
------------- GOverlay Tester ------------
--> Version 0.5
--> Arguments :D:\Downloads2018\GOverlay_Tester_v05\GOverlay_Tester.exe
------------- OS Info ------------
--> Version: 6.2.9200.0
--> Name: Microsoft Windows 10 Pro
--> Windows is 64 bits
------------- File Drivers Check ------------
System32 located at: C:\WINDOWS\system32\
LibUsb0.dll found
--> Version: 1.2.2.0
drivers\libusb0.sys found
------------- LibUsb Driver Status ------------
LibUsb Kernel version: 0.0.0.0
------------- Related Devices Connected ------------
--> libusb-win32 Generic Device
----> Service: libusb0
----> Description: libusb-win32 Generic Device
----> Manufacturer: (Undefined Vendor)
----> DeviceID: ROOT\LIBUSB-WIN32_DEVICES\0000
----> Status: 0
--> LCDsysinfo (GOverlay) 2.0
----> Service: WinUSB
----> Description: LCDsysinfo (GOverlay) 2.0
----> Manufacturer: Clay Logic
----> DeviceID: USB\VID_20A0&PID_41ED\2CDSZ
----> Status: 0
------------- Devices Detected ------------
Failed getting DC info: GUID muss 32 Ziffern mit 4 Bindestrichen enthalten (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).: bei System.Guid..ctor(String g)
bei LibUsbDotNet.WinUsb.WinUsbRegistry.WinUsbRegistryCallBack(IntPtr deviceInfoSet, Int32 deviceIndex, SP_DEVINFO_DATA& deviceInfoData, Object classEnumeratorCallbackParam1)
bei LibUsbDotNet.Internal.SetupApi.EnumClassDevs(String enumerator, DICFG flags, ClassEnumeratorDelegate classEnumeratorCallback, Object classEnumeratorCallbackParam1)
bei LibUsbDotNet.UsbDevice.get_AllWinUsbDevices()
bei LibUsbDotNet.UsbDevice.get_AllDevices()
bei WindowsApplication1.Form1.Button1_Click(Object sender, EventArgs e)
------------- LibUsb Utility Devices Report ------------
------------- Listing all USB Connected Devices ------------
Report generated OK
log.txt
The Log text of the GOverlay Software wen i Start this
(453.52 KiB) Downloaded 252 times
report.txt
(13.55 KiB) Downloaded 262 times
Honnes
Postby TheLaGmAn » Sat Mar 09, 2019 5:50 pm
That is very strange, do you have a laptop or other computer to test it out?
Postby TheLaGmAn » Sat Mar 09, 2019 5:54 pm
The driver doesnt seem to be installed properly, this line
is reporting that no driver is installed for libusb, it should be like
LibUsb Kernel version: 1.2.2.0
How did you installed the driver?
PreviousNext
Users browsing this forum: Bing [Bot] and 2 guests
