Help Please Not Detected.......
Postby Scorpion » Tue Dec 11, 2018 7:46 am
I have the LCD 3.5 it status shows "yellow" (Not Detected)
The logs show 12/11/2018 01:37:55:LCDSysInfo - Init
12/11/2018 01:37:55:LCDSysInfo - Error opening device
12/11/2018 01:37:56:LCDSysInfo - Init
12/11/2018 01:37:56:LCDSysInfo - Error opening device
12/11/2018 01:37:57:LCDSysInfo - Init
12/11/2018 01:37:57:LCDSysInfo - Error opening device
12/11/2018 01:37:58:LCDSysInfo - Init
12/11/2018 01:37:58:LCDSysInfo - Error opening device
12/11/2018 01:37:59:LCDSysInfo - Init
Here are the driver install:
Scorpion
Re: Help Please Not Detected.......
Postby TheLaGmAn » Tue Dec 11, 2018 1:21 pm
Please run the goverlay tester and post the result
http://goverlay.com/UserFiles/GOverlay/ ... er_v05.zip
Postby Scorpion » Tue Dec 11, 2018 3:36 pm
Here is the Report.txt file
report.txt
(2.89 KiB) Downloaded 1120 times
Scorpion
Postby TheLaGmAn » Tue Dec 11, 2018 4:15 pm
The results are okay,
The log you posted before is showing that the LCD 1.0 (the 2.8'' screen) is the one not being detected, the 2.0 (3.5'' screen) seems fine.
Where in GOverlay it shows not detected? Are you going into the LCDSysInfo 3.5'' tab?
Postby Scorpion » Tue Dec 11, 2018 4:36 pm
I have the 3.5 inch Display...I mean I actually measured it??
When I go to the LCDSysinfo 2.8" Device
When I go to the LCDSysinfo 3.5" Device
Then here is the "STATUS"
Scorpion
Postby TheLaGmAn » Tue Dec 11, 2018 5:23 pm
Okay, install or run teamviewer and send me an email with the code at support@goverlay.com so i can take a look.
The display should be working, could be a bug with the notification on that page.
https://www.teamviewer.com/en/download/windows/
Postby TheLaGmAn » Tue Dec 11, 2018 6:25 pm
issue solved, was a bug on the icon color, wasnt affecting the actual use of the device, i will post a beta that fixes it
Postby ajpowell » Fri Jan 11, 2019 6:23 pm
Help please mine is the same not detected
ajpowell
Postby TheLaGmAn » Fri Jan 11, 2019 7:05 pm
What device do you have, the 2.8'' or 3.5'' ?
Postby ajpowell » Fri Jan 11, 2019 7:27 pm
TheLaGmAn wrote:What device do you have, the 2.8'' or 3.5'' ?
3.5
ajpowell
Users browsing this forum: No registered users and 10 guests
