Visual Scripting, Questions
Re: Visual Scripting, Questions
Postby Mr.Pum@ » Sun Dec 23, 2018 7:01 am
TheLaGmAn wrote:In the Math Round box, the second value is the amount of decimals, its empty which means 0 decimals.
Put a 1 in there and you will get round with one decimal.
Apparently I'm doing something wrong:
https://imgur.com/HhiQWqG
Mr.Pum@
Postby TheLaGmAn » Sun Dec 23, 2018 4:59 pm
can you try putting a 2 in the round and see what happens?
Postby Mr.Pum@ » Sun Dec 23, 2018 5:27 pm
TheLaGmAn wrote:can you try putting a 2 in the round and see what happens?
I tried. It turns out the same thing as an example:
1280KB/s---draw like 1MB/s
Mr.Pum@
Postby TheLaGmAn » Mon Dec 24, 2018 8:47 pm
try beta
1.6.6.3_bya
Postby Mr.Pum@ » Tue Dec 25, 2018 7:56 pm
TheLaGmAn wrote:try beta
1.6.6.3_bya
It works now! Thank!
https://imgur.com/Io3y3LV
Mr.Pum@
Postby TheLaGmAn » Tue Dec 25, 2018 11:10 pm
great, if you can, share the VS with what it does so the users can have a couple of examples
Postby Mr.Pum@ » Wed Dec 26, 2018 4:27 pm
TheLaGmAn wrote:great, if you can, share the VS with what it does so the users can have a couple of examples
The original author of the script korenchkin
Profile: JustTheBasics (LCD2)
korenchkin version - KBit/s -> MBit/s -> GBit/s
network speed humanizationMBit
my edited version - KB/s -> MB/s -> GB/s
network speed humanizationMB.govVS
(11.83 KiB) Downloaded 1740 times
network speed humanization.govVS
(12.8 KiB) Downloaded 1749 times
Mr.Pum@
Postby Giveatry » Thu Mar 14, 2019 5:41 pm
TheLaGmAn wrote:korenchkin version - KBit/s -> MBit/s -> GBit/s
If I want to import the script Goverlay crashes.
Crash
Giveatry
Postby TheLaGmAn » Wed Mar 20, 2019 2:02 pm
I just released 1.6.9 ,
Try that version (go to whats new, check for new version), it should be fixed
Postby Giveatry » Thu Mar 21, 2019 5:10 pm
TheLaGmAn wrote:I just released 1.6.9
Perfect, with the update, the problem has resolved in the air. Thank you!
Giveatry
