Bug on clock in notification box
Postby enderep12 » Sat Aug 18, 2018 6:18 am
Hi everyone,
I have a bug on the 3.5" LCDSysinfo's "Notification Box". Sometimes, the clock (I put it to 24h time format without seconds) only shows 3 numbers. Most of the time this involves a 4 somewhere in the clock.
Unfortunately I am not able to reproduce this in any way, however I managed to snap a screenshot:
https://imgur.com/Tc4DN25
This was yesterday at 08:54...
My suspicion is that this might have something to do with the size of the numbers and the available space.. However as mentioned, this does not happen every time - e.g. 08:14 works fine, then it might happen again at 08:24, etc.
Do you have any idea what could be causing this?
Edit:
And it happened again on 08:24, I managed to snap a video of it:
https://gfycat.com/MeagerBlondGibbon
As you can see, the clock jumps to "08:2" and then on 08:25 it jumped back from "08:2" to "08:25"
enderep12
Re: Bug on clock in notification box
Postby enderep12 » Mon Aug 20, 2018 6:51 am
Sorry for the double post, I did some more testing:
During the bug (right now it's showing "08:4" the full 10 minutes from 08:40 to 08:50), it does not matter if I change:
  • font size
  • font type (bold/regular)
  • weather (enable/disable)
  • 24 vs. am/pm
I basically fiddled with all settings that are available for the notification box and the bug still occurs. I reloaded the display after changing every settings, so it was on a fresh draw.
enderep12
Postby TheLaGmAn » Wed Aug 29, 2018 3:34 pm
Thanks for the info.
It can either be the number not fitting (which would be weird because it does fit) or an issue drawing the change.
Can you add a second notification box so you can compare if it happens on both at the same time?
Postby enderep12 » Fri Aug 31, 2018 12:11 pm
thanks for the response.
I added a second bar and will report back as soon as it happens.
What is noticeable immediately is, that the 2nd bar will not show the weather (as well as the weather icon), even though the settings on both bars are exactly the same. Not sure if this is intended. On reload of the screen with the 2nd bar the weather icon pops up VERY quickly and instantly disappears.
Edit: Scratch that, this happened because my TS talker was overlapping the 2nd bar. I have now set up a screen with 2 bars and no overlaps.
It's currently 14:10 where I am, so the bug might reappear in 4 or 14min.
Edit 2:
It happened again, 14:24. With 2 bars and on a completely new template I made just for testing with nothing else except those two bars. Screen:
https://i.imgur.com/gs78ZKP.jpg
Another thing I noticed, might be related, is that my logs are getting flooded with:
31.08.2018 14:25:35:LCDSysinfo2 - Rectangle sizes are invalid considering line size of 0
31.08.2018 14:25:36:LCDSysinfo2 - Rectangle sizes are invalid considering line size of 0
31.08.2018 14:25:37:LCDSysinfo2 - Rectangle sizes are invalid considering line size of 0
enderep12
Postby TheLaGmAn » Sat Sep 01, 2018 3:33 pm
Can you try with hour with seconds? see if there is any issue there
Postby enderep12 » Mon Sep 03, 2018 6:22 pm
Yes, same issue. For example right now it showed "20:22:1" and 20:22:2" instead of 20:22:14 / 20:22:24... so it definitely has something to do with the 4
I made a video of a full minute, uncut:
https://www.youtube.com/watch?v=P7Z104ZaoLo
enderep12
Postby TheLaGmAn » Fri Sep 21, 2018 3:50 pm
Try with the BETA 1.6.4.11_cgu , see if it does the same
Postby enderep12 » Thu Oct 04, 2018 2:25 pm
Looking good so far. Was not able to reproduce it since installing this beta!
Thanks once again for the support!
enderep12
Users browsing this forum: No registered users and 31 guests
