Screen artifacts/corruption issues
Postby Millerized » Sat Mar 03, 2018 1:21 pm
So I keep seeing some strange corruption issues onscreen, I have tried different USB ports, and 3 different cables, but every so often the screen just does not display clearly...
As you can see there is corruption on Network usage, time, GPU/CPU usage, and even a little on the memory usage elements.
Any idea what the problem might be, and how to fix it?
Millerized
Re: Screen artifacts/corruption issues
Postby SubSonix » Sat Mar 03, 2018 3:23 pm
The elements you're placing are too close together. Move them apart and save and you'll see what I mean.
SubSonix
Users browsing this forum: Google [Bot] and 5 guests
