Change profile on display based on game running
Postby vrod » Thu Dec 21, 2017 10:01 am
Hi.
I am running RTSS and have selected my .exe programs.
In GOverlay, I went to the tab under 2.8"Display/on Gaming, and made a profile with the exact same as the .exe program.
That being said, I am not trying to display anything on screen. I want to change the display graphs on my 2.8" LCD unit based on what game I am playing.
How can I do this?
If I can send a command line option (to change the profile) without using the gaming option, then that is OK too.
thanks!
vrod
Re: Change profile on display based on game running
Postby TheLaGmAn » Thu Dec 21, 2017 1:56 pm
If the .exe matches the game, it should automatically load that profile, but do you have RTSS running? RTSS has to detect the game having DX/OpenGL for it to appear
Postby vrod » Fri Dec 22, 2017 8:21 am
OIC.
No, it does not have DX nor Open GL in it.
It really isn't even a game. Just an .exe I made that does absolutely nothing.
I was hoping that GOverlay would see my .exe and then change to another profile.
Is there any other way to change profiles? (Besides manually)
vrod
Postby TheLaGmAn » Fri Dec 22, 2017 4:58 pm
there isnt a way to do it without RTSS, i will see if i can add something for the next version.
The easiest way to change profiles (altough its a manual process) is to right click on the goverlay icon
Postby vrod » Sat Dec 23, 2017 12:57 pm
I see.
Yeah, it would be great if you could add a programmable shortcut key (hotkey) that would jump to a specific profile.
I am not using any "OnDisplay" screens, just a 2.8" display. Looks good too.
I would like to be able able to black the screen out (could be done with a blank profile).
Changing to another profile would be good too, although just turning the display on/off would be good enough for me now.
I am trying to simulate my cockpit turning on or off.
Here is my setup;
[Imgur](https://i.imgur.com/vHOYvHU.jpg)
thanks!!!
vrod
Postby TheLaGmAn » Wed Feb 07, 2018 4:29 pm
hey vrod, try the new beta which has support for loading profiles by command line
ex: GOverlay.exe -activateprofile3.5 "template - blue (LCD2)"
viewtopic.php?f=3&t=488
Postby vrod » Sun Mar 04, 2018 12:27 pm
Thanks! I will try it out in the next couple days!
vrod
Postby vrod » Tue Mar 06, 2018 8:28 pm
I don't have a 3.5" display, but the smaller one.
Would it still work?
vrod
Postby vrod » Tue Mar 06, 2018 8:50 pm
hmmm. can't get it to work.
Guess it is only for the 3.5 display. :(
vrod
Postby TheLaGmAn » Tue Mar 06, 2018 10:47 pm
i will see if i can port it to 2.8 as well
Users browsing this forum: Google [Bot] and 1 guest
