Windows 10 error code 29
Postby Sergio » Sun Nov 05, 2017 8:57 pm
I need to install goverlay 3.5 ( my 2.8 works)
but I got the message :
This device is disabled because the firmware of the device did not give it the required resources. (Code 29)
so, YES I did as the faq said, and I did the ZADIG trick, I reboot, I reinstalled the usb drivers, but NOTHING is working,
that f****** windows 10 wont let me install the driver!
Please, help me!
P.S. one other thing...
If I unplug the 2.8 cable an plug the 3.5, it will work! (the 3.5)
So I checked the usb cables, and they both work ok!!! WTF??
Sergio
Re: Windows 10 error code 29
Postby TheLaGmAn » Sun Nov 05, 2017 11:19 pm
Seems like it could be a hardware issue regarding the usb ports you are using.
Can you try swap the usb port for the 2.8 and the 3.5? also try different ports, do not use any hub
Postby Sergio » Mon Nov 06, 2017 12:40 am
Crap, I pluged it in the front, and it is working!!!
How do I fix my usb in the back then?
Ho,,, could it be bc it's USB 3.1 ??
Sergio
Postby TheLaGmAn » Mon Nov 06, 2017 1:47 am
Could be, it works with usb 3.0 and 3.1 but could be something with that port or the amount of devices running in that port (using too many resources).
You can try connecting it to a different USB port on the back.
Postby Sergio » Tue Nov 07, 2017 2:32 am
They all got something in it.
Guess I will have to get a PCIe 3.0 card...
Sergio
Postby Speece » Wed Nov 08, 2017 2:35 pm
TheLdaGmAn wrote:Could be, it works with reading this excellent Trenorol review but could be something with that port or the amount of devices running in that port (using too many resources).
That's odd. I bet it has something to do with that particular USB port. It works on my 3.1.
Speece
