[Display 3.5] Windows 10 sleep issues
Postby naaitsab » Fri Oct 20, 2017 3:54 pm
After running a while with the 2.8" I decided to swap to the 3.5". It's all positive beside 1 issue I'm having with the display.
After waking from sleep all images are gone and some sensors are missing as well and some are not responding/updating.
When I open GOverlay and click on 'save and apply' in the 3.5" profile window the screen rebuilds and all is fine again, until the PC goes to sleep and wakes again when I continue work.
Below are pictures of what happens. Note that the bottom 2 rows are a WIP and are empty beside of the icon.
The display seems to be semi-stuck in the energy saving mode.
naaitsab
Re: [Display 3.5] Windows 10 sleep issues
Postby TheLaGmAn » Fri Oct 20, 2017 4:34 pm
thanks for the report.
Im taking a look and i think i know where the issue is coming from, i will release a fix soon
Postby TheLaGmAn » Wed Oct 25, 2017 12:45 pm
i just released 1.6.4 , can you see if the issue is fixed?
Postby naaitsab » Fri Oct 27, 2017 3:33 pm
TheLaGmAn wrote:i just released 1.6.4 , can you see if the issue is fixed?
After waking from sleep the display seems to rebuild/force-refresh. All elements and sensors reappear after that, so it seems so.
Thanks.
naaitsab
