Display 2.8 working, but not the 3.5
Postby Sergio » Tue Oct 17, 2017 11:57 pm
I just got the 3.5 display, but it's not working (stuck on run goverlay for config), but my 2.8 is working nicely
here it goes :
If I plug the 2 of them at the same time: on the STATUS page of goverlay BOTH are GREEN, enable and detected but only the 2.8 is working and the 3.5 stuck at run goverlay for config.
If I plug the 3.5 alone: STATUS page is YELLOW for the 2.8 AND the 3.5 and BOTH are enable and NOT detected.
if I plug the 2.8 alone, BOTH ARE GREEN, 2.8 and 3.5 enable AND detected!!!
GOverlay version 1.6.3
yes, I put a profile on the 3.5 (tested all of them)
And the log is killing me with this:
17/oct./2017 19:55:40:LCDSysInfo2 - Error opening device
17/oct./2017 19:55:40:LCDSysInfo2 - Init
17/oct./2017 19:55:40:ProcessWatch - Resetting Watcher "\Process(*)\% Processor Time" -si 1
17/oct./2017 19:55:39:LCDSysInfo2 - Error opening device
17/oct./2017 19:55:39:LCDSysInfo2 - Init
17/oct./2017 19:55:38:LCDSysInfo2 - Error opening device
Can someone help me??
Sergio
Re: Display 2.8 working, but not the 3.5
Postby Elrynill » Wed Oct 18, 2017 10:42 am
Hey,
This may sound stupid, but did you install the separate driver for lcdsys 2.0 needed for the 3.5inch display? Both devices require a different driver to run.
If not, the driver is located in your goverlay directory, you still need to disable driver signature verification.
Elrynill
Postby Sergio » Wed Oct 18, 2017 12:23 pm
I need to install a second GOVERLAY software?
And I think that we need to disable the driver signature verification only once, no??
do we need to disable for each display ?
Thanks Elrnill
Sergio
Postby TheLaGmAn » Wed Oct 18, 2017 12:43 pm
You need to install the driver for the second display as well (not the GOverlay software, the DRIVER for the device) as the FAQ guide shows.
You will need to disable driver signature enforcement one more time so you are able to install it and after that GOverlay should be able to detect the device.
Postby Sergio » Wed Oct 18, 2017 11:17 pm
WORKING
Haaaaa, NICE!
Thanks to you, guys, now this week-end, I will play with profile creation!
Now, after the 3.5 inch, lets get serious and get a 7 inch!!!
Sergio
Postby Vanguardas » Thu Nov 30, 2017 6:29 am
I was about to ask this question cause I intend to order a 3.5'' model to add to my 2.8'' model. 2.8'' goes inside thecase while the 3.5'' goes outside the case. THANKS FOR POSTING THIS THREAD. I LOVE YOU HANDSOME MEN :D
Vanguardas
