LCDSysInfo 3.5" with Windows 10
Postby itlvk » Tue Oct 03, 2017 2:26 pm
I am using LCDSysInfo 3.5" on Windows 10 Pro x64 with GOverplay driver 1.62 but I cannot install driver
Please help me
itlvk
Re: LCDSysInfo 3.5" with Windows 10
Postby itlvk » Tue Oct 03, 2017 2:49 pm
itlvk
Postby TheLaGmAn » Tue Oct 03, 2017 6:41 pm
glad to hear that got it solved for you.
Did you rebooted with driver signature disabled as the FAQ says with the normal drive install procedure?
Postby Nimzovich » Sun Dec 10, 2017 4:23 am
Having to disable driver signature is a hassle and it would be helpful if you could eliminate the need for GOverlay users having to do so. After every major Windows update, which now come frequently, I have to go through all the steps to disable driver signature, which for me includes having to attach a wired keyboard (which I have to dig out of the attic).
Also, it would be helpful if you could put all the steps in a pdf file so they can be printed instead of having to scroll through the screen shots.
Nimzovich
