LCD 2.8 cannot change profile while gaming
Re: LCD 2.8 cannot change profile while gaming
Postby colonel » Wed Sep 20, 2017 3:00 pm
yes, it detected and run default prifle
colonel
Postby TheLaGmAn » Wed Sep 20, 2017 5:40 pm
thats the profile you must use for gaming.
Cant you add the sensors and elements there and make it look as you want to?
Postby colonel » Sat Sep 30, 2017 5:05 am
i have same profile beetwen gaming nad windows, different only FPS sensor. I try reinstall but still same problem, my gaming sensor always back to default. I cant describe it for you, please help via teamviewr :(
colonel
Postby TheLaGmAn » Tue Oct 03, 2017 6:42 pm
okay, send me an email to support@goverlay.com and we will take a look
Postby Dunmait » Tue Oct 24, 2017 11:35 pm
Hello, I have a related question.
Is it possible to copy a profile as default profile, for example, I created a profile for Overwatch which I really liked. Can I make this profile the default one, without having to go through the whole changing process in the default profile?
Dunmait
Postby TheLaGmAn » Wed Oct 25, 2017 12:36 pm
yes, export the profile and when you import it, just leave the profile name blank (without any text at all) and it will ask you to confirm if you want it to be the default profile.
Postby Dunmait » Wed Oct 25, 2017 11:39 pm
Thanks! that solved it!
Dunmait
