LCD 2.8 cannot change profile while gaming
Postby colonel » Sun Sep 17, 2017 3:45 am
i use 1.6.2 version. i try to chgane profile while gaming, save and apply but if it running still default profile. If i restart my goverlay, it's default again. please help
colonel
Re: LCD 2.8 cannot change profile while gaming
Postby TheLaGmAn » Sun Sep 17, 2017 4:49 am
If you have gaming mode enabled it will always switch to the according profile found for gaming.
So if you are in-gaming mode, it will look for a profile that would match the application .exe, if not found, it will use the default gaming profile.
If you dont want that to happen you can disable the gaming profile and you have to always manually select a profile.
Is that what you were talking about?
Postby colonel » Sun Sep 17, 2017 5:16 am
what you mean "match the application .exe" ? i have a profile gaming and import from them. Before i reinstalled my pc its work. I try to put gaming profile on windows profile, but FPS not work
colonel
Postby TheLaGmAn » Sun Sep 17, 2017 2:16 pm
Lets go for the basics first.
1. Do you have RTSS running?
2. When you start a game, does it show "Game detected.." in the LCD screen?
Postby colonel » Sun Sep 17, 2017 2:28 pm
1. yes i have rtss and its running, but in default profile
2. yes
the problem : when i change the profile of gaming with my profile, and save and i start game, RTTS running but with default profile. It happen only in gaming mode, not windows mode. And if i restart my pc, its default profile again.
sory my bad english :(
colonel
Postby TheLaGmAn » Sun Sep 17, 2017 2:47 pm
while on gaming you CANT manually select a gaming profile.
Gaming profiles are AUTOMATIC.
If you want a specific profile, for, lets say, company of heroes 2, you need to create a profile named "reliccoh2.exe" which is the .EXE file name the game launches and that profile will appear when you open the game (and not the default one).
What game are you trying to use your custom profile for?
Postby colonel » Tue Sep 19, 2017 11:12 am
i use .gov file profile, not exe and it work just for window only not gaming. Or can you help me with teamviewer? thanks
colonel
Postby TheLaGmAn » Tue Sep 19, 2017 2:15 pm
Postby colonel » Tue Sep 19, 2017 2:32 pm
all gaming, all RTSS detect cant change to profile gaming.
colonel
Postby TheLaGmAn » Tue Sep 19, 2017 5:03 pm
when you start up a game, does it show the "game detected" blue screen on the device?
