Goverlay stops work after update to 1.5.9
Postby viktor048 » Thu Sep 14, 2017 7:05 am
I just purchased your device. Downloaded the program, offered to update. After updating to version 159 the program does not work. Windows writes: the program is closed and closes. Help me please! Perhaps, if you try the older version, it will start. I can not find where to download the older one.
viktor048
Re: Goverlay stops work after update to 1.5.9
Postby viktor048 » Thu Sep 14, 2017 8:45 am
I tried it on another computer - it works for 15 minutes and then it also closes and does not start any more.
viktor048
Postby viktor048 » Fri Sep 15, 2017 4:13 am
The problem is solved. Thank You TheLaGman.
viktor048
Users browsing this forum: No registered users and 14 guests
