Goverlay stops work after update to 1.6.0
Postby Kabron » Sun Sep 10, 2017 11:08 am
It shows only black profile window and I could not do anything with it.
GoverlayTester shows no problems. After return to older version the same bug.
Coul not upload the image, because of "Sorry, the board attachment quota has been reached."
What the crasy thing?
Kabron
Re: Goverlay stops work after update to 1.6.0
Postby TheLaGmAn » Sun Sep 10, 2017 3:19 pm
So if you return to the old version you have the same issue? if that so, it could be an issue with your profile/goverlay configuration stored in the registry not loading.
Do you have any errors in the logs tab?
You can contact me at support@goverlay.com and we can take a look with teamviewer to see whats going on
Postby viktor048 » Thu Sep 14, 2017 6:59 am
After updating to version 159 the program does not work. Windows writes: the program is closed and closes. Help me please! I already wrote you a letter. Just in case the food is still here
viktor048
Postby viktor048 » Thu Sep 14, 2017 7:01 am
Perhaps, if you try the older version, it will start. I can not find where to download the older one.
viktor048
Postby TheLaGmAn » Thu Sep 14, 2017 1:19 pm
Hi Viktor, sent you an email so we can check your issue
Postby Kabron » Sat Sep 16, 2017 7:51 am
Now v 1.6.1 after registry cleaning all Goverlay items - the same bug.
What's the shit? I could not upload any attachment? so see here:
16.09.2017 10:42:13:GOverlay Started
16.09.2017 10:42:13:Version: 1.6.1
16.09.2017 10:42:13:Looking for plugins
16.09.2017 10:42:13:Plugins - Checking: C:\Goverlay\Plugins\APCUPS.dll
16.09.2017 10:42:13:PluginServices - Error loading plugin APCUPS, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Не удается загрузить один или более запрошенных типов. Обратитесь к свойству LoaderExceptions для получения дополнительных сведений.
16.09.2017 10:42:13:Plugins - Checking: C:\Goverlay\Plugins\Aquasuite.dll
16.09.2017 10:42:13:Plugin found: C:\Goverlay\Plugins\Aquasuite.dll: GOverlayPlugin.Aquasuite.Class1
16.09.2017 10:42:13:Plugin Name: Aquasuite for display: lcdsys
16.09.2017 10:42:13:plugin has option: xmlfile
16.09.2017 10:42:13:Looking for sensors for plugin Aquasuite
16.09.2017 10:42:14:Error loading sensors:Пустое имя пути не допускается.: в System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
в System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access)
в GOverlayPlugin.Aquasuite.Class1.AvailableSensors(Hashtable pluginOptions) в D:\VB\goverlay\GOverlay\GOverlay\bin\Debug\Plugins\Examples\Aquasuite\Class1.vb:строка 114
16.09.2017 10:42:14:PluginServices - Error loading plugin Aquasuite, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Ссылка на объект не указывает на экземпляр объекта.
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\COH2.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\COH2.dll: GOverlayPlugin.COH2.Class1
16.09.2017 10:42:14:Coh2 - File missing: C:\Users\vlady\Documents\My Games\Company of Heroes 2\warnings.log
16.09.2017 10:42:14:Plugin Name: COH2 Plugin for display: lcdsys
16.09.2017 10:42:14:plugin has option: coh2path
16.09.2017 10:42:14:Plugin is disabled
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\DemoComplexDraw.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\DemoComplexDraw.dll: GOverlayPlugin.DemoComplexDraw.PluginClass
16.09.2017 10:42:14:Plugin Name: GOverlay Example Plugin: Complex Draw for display: lcdsys
16.09.2017 10:42:14:plugin has option: unit
16.09.2017 10:42:14:plugin has option: lineColor
16.09.2017 10:42:14:plugin has option: note
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\DemoSimpleDraw.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\DemoSimpleDraw.dll: GOverlayPlugin.DemoSimpleDraw.PluginClass
16.09.2017 10:42:14:Plugin Name: GOverlay Example Plugin: Simple Draw for display: lcdsys
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\ETS2.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\ETS2.dll: GOverlayPlugin.ETS2.Class1
16.09.2017 10:42:14:Plugin Name: Euro Truck Simulator 2 for display: lcdsys
16.09.2017 10:42:14:plugin has option: reqimages
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\HWInfo.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\HWInfo.dll: GOverlayPlugin.HWInfo.Class1
16.09.2017 10:42:14:Plugin Name: HWiNFO for display: lcdsys
16.09.2017 10:42:14:plugin has option: metric
16.09.2017 10:42:14:Looking for sensors for plugin HWiNFO
16.09.2017 10:42:14:HwInfo - Connected to hMapFile
16.09.2017 10:42:14:HwInfo -hMapFile is invalid
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\IL2COD.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\IL2COD.dll: GOverlayPlugin.ILD2COD.Class1
16.09.2017 10:42:14:Plugin Name: IL2 Cliffs of Dover (ATAG) for display: lcdsys
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\Plugin1.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\Plugin1.dll: GOverlayPlugin.Plugin1.Class1
16.09.2017 10:42:14:Plugin Name: GOverlay Example Plugin 1 for display: lcdsys
16.09.2017 10:42:14:plugin has option: timeout
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\Plugin2.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\Plugin2.dll: GOverlayPlugin.Plugin2.Class1
16.09.2017 10:42:14:Plugin Name: CrystalMark DiskInfo for display: lcdsys
16.09.2017 10:42:14:plugin has option: regkey
16.09.2017 10:42:14:Looking for sensors for plugin CrystalMark DiskInfo
16.09.2017 10:42:14:Error loading sensors, Is CristalMark running with External Applications enabled?Ссылка на объект не указывает на экземпляр объекта.: в GOverlayPlugin.Plugin2.Class1.AvailableSensors(Hashtable pluginOptions) в D:\VB\goverlay\GOverlay\GOverlay\bin\Debug\Plugins\Examples\Plugin 2\Class1.vb:строка 74
16.09.2017 10:42:14:PluginServices - Error loading plugin Plugin2, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Ссылка на объект не указывает на экземпляр объекта.
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\SensorMix.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\SensorMix.dll: GOverlayPlugin.SensorMix.Class1
16.09.2017 10:42:14:Plugin Name: Sensors Mix for display: lcdsys
16.09.2017 10:42:14:plugin has option: g4n
16.09.2017 10:42:14:plugin has option: g3s1
16.09.2017 10:42:14:plugin has option: g5s2
16.09.2017 10:42:14:plugin has option: g1s2
16.09.2017 10:42:14:plugin has option: g3s3
16.09.2017 10:42:14:plugin has option: g5s4
16.09.2017 10:42:14:plugin has option: g5n
16.09.2017 10:42:14:plugin has option: g1n
16.09.2017 10:42:14:plugin has option: g4s1
16.09.2017 10:42:14:plugin has option: g2s2
16.09.2017 10:42:14:plugin has option: g4s3
16.09.2017 10:42:14:plugin has option: g2s4
16.09.2017 10:42:14:plugin has option: g2n
16.09.2017 10:42:14:plugin has option: g1s4
16.09.2017 10:42:14:plugin has option: g5s1
16.09.2017 10:42:14:plugin has option: g1s1
16.09.2017 10:42:14:plugin has option: g3s2
16.09.2017 10:42:14:plugin has option: g5s3
16.09.2017 10:42:14:plugin has option: g1s3
16.09.2017 10:42:14:plugin has option: g3s4
16.09.2017 10:42:14:plugin has option: g3n
16.09.2017 10:42:14:plugin has option: g2s1
16.09.2017 10:42:14:plugin has option: g4s2
16.09.2017 10:42:14:plugin has option: g2s3
16.09.2017 10:42:14:plugin has option: g4s4
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\SimBin.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\SimBin.dll: GOverlayPlugin.SimBin.Class1
16.09.2017 10:42:14:Plugin Name: SimBin Car Stats for display: lcdsys
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\Slideshow.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\Slideshow.dll: GOverlayPlugin.Slideshow.Class1
16.09.2017 10:42:14:Plugin Name: Slideshow for display: lcdsys
16.09.2017 10:42:14:plugin has option: i10
16.09.2017 10:42:14:plugin has option: i2
16.09.2017 10:42:14:plugin has option: i3
16.09.2017 10:42:14:plugin has option: i4
16.09.2017 10:42:14:plugin has option: i5
16.09.2017 10:42:14:plugin has option: i6
16.09.2017 10:42:14:plugin has option: itime
16.09.2017 10:42:14:plugin has option: i8
16.09.2017 10:42:14:plugin has option: i9
16.09.2017 10:42:14:plugin has option: irandom
16.09.2017 10:42:14:plugin has option: i7
16.09.2017 10:42:14:Plugins - Checking: C:\Goverlay\Plugins\SpeedFan.dll
16.09.2017 10:42:14:Plugin found: C:\Goverlay\Plugins\SpeedFan.dll: GOverlayPlugin.SpeedFan.Class1
16.09.2017 10:42:14:Plugin Name: SpeedFan Plugin for display: lcdsys
16.09.2017 10:42:14:GOverlay is running as administrator: True
16.09.2017 10:42:14:LCDSysInfo - First init run
16.09.2017 10:42:14:LCDSysInfo - Init
16.09.2017 10:42:14:Device SS: lcdsz / lcdsz
16.09.2017 10:42:14:Device FN: Clay Logic - LCDsysinfo (GOverlay)
16.09.2017 10:42:14:LCDSysInfo - Successfully inited
16.09.2017 10:42:14:LCDSysinfo - Set brigthness to 255
16.09.2017 10:42:15:LCDSysInfo - Device Serial: 23010288146871113357
16.09.2017 10:42:15:LCDSysInfo - Device FW: 122
16.09.2017 10:42:15:LCDSysInfo2 - First init run
16.09.2017 10:42:15:LCDSysInfo2 - Init
16.09.2017 10:42:15:LCDSysInfo2 - Error opening device
16.09.2017 10:42:15:Reload settings started
16.09.2017 10:42:15:ClearSettingsMarks - Started
16.09.2017 10:42:15:Emptying all marks
16.09.2017 10:42:15:Reload settings checkpoint 1
16.09.2017 10:42:15:LCDSys Cache is Enabled
16.09.2017 10:42:15:LCDSys2 Cache is Enabled
16.09.2017 10:42:15:Reload settings checkpoint 2
16.09.2017 10:42:15:Reload settings checkpoint 3
16.09.2017 10:42:15:Reload settings checkpoint 4
16.09.2017 10:42:15:Reload settings checkpoint 5
16.09.2017 10:42:15:Reload settings checkpoint 6
16.09.2017 10:42:15:Reload settings checkpoint 7
16.09.2017 10:42:15:Loading GameProfiles
16.09.2017 10:42:15:Added profile for WG: eurotrucks2.exe
16.09.2017 10:42:15:Added profile for WG: race_steam.exe
16.09.2017 10:42:15:Added profile for WG: RelicCoH2.exe
16.09.2017 10:42:15:Added profile for WG: eurotrucks2.exe (wg)
16.09.2017 10:42:15:Added profile for WG: doomknight87_profile_2.2
16.09.2017 10:42:15:Loading OnWindowsProfiles
16.09.2017 10:42:15:Added profile for OW: default (wg)
16.09.2017 10:42:15:Added profile for OW: eurotrucks2.exe (wg)
16.09.2017 10:42:15:Added profile for OW: reliccoh2.exe (wg)
16.09.2017 10:42:15:Added profile for OW: doomknight87_profile
16.09.2017 10:42:15:Added profile for OW: doomknight87_profile_2.2
16.09.2017 10:42:15:ReloadSettings - Profile OnWindows using: Default (due to invalid profile)
16.09.2017 10:42:15:Profiles Load Ended
16.09.2017 10:42:15:Loading lcdsys2 GameProfiles
16.09.2017 10:42:15:Profiles lcdsys2 Load Ended
16.09.2017 10:42:15:Error loading some sensors: Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2' :: в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
в System.Collections.Hashtable.Add(Object key, Object value)
в GOverlay.Form1.e(Object A_0)
в GOverlay.Form1.d(Object A_0)
16.09.2017 10:42:15:LCDSysinfo - Set brigthness to 100
16.09.2017 10:42:15:ReloadMarks - Started
16.09.2017 10:42:15:ReloadMarks - Error reading marks: Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2': в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
в GOverlay.Form1.b(String A_0, String A_1)
16.09.2017 10:42:15:ReloadMarks - Ended
16.09.2017 10:42:15:ReloadMarks - Error loading lcdsys2/ALL elements : Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2' : в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
16.09.2017 10:42:15:Stopping teamspeak handler
16.09.2017 10:42:15:Reload General (3d-Render) Mark: [time]
16.09.2017 10:42:15:Reload General (3d-Render) Mark: [render]
16.09.2017 10:42:15:Reload General (3d-Render) Mark: [ping]
16.09.2017 10:42:15:Reload General (3d-Render) Mark: [fps]
16.09.2017 10:42:15:Culture Type is: 1
16.09.2017 10:42:15:Reload settings end
16.09.2017 10:42:15:Color format loading
16.09.2017 10:42:15:Ping Thread Started
16.09.2017 10:42:15:Starting thread GUI
16.09.2017 10:42:15:OHMD is enabled, initing
16.09.2017 10:42:15:Starting Ticker
16.09.2017 10:42:15:Ticker thread started
16.09.2017 10:42:15:Checking for new version in method: Silent
16.09.2017 10:42:15:Ticker GUI thread started
16.09.2017 10:42:16:Req clear waiting 1
16.09.2017 10:42:16:LCDSysInfo2 - Init
16.09.2017 10:42:16:LCDSysInfo2 - Error opening device
16.09.2017 10:42:17:LCDSys - Screen clear requested and done
16.09.2017 10:42:17:DoLCDSys Exception: Ссылка на объект не указывает на экземпляр объекта.: в ab.b()
16.09.2017 10:42:17:LCDSysInfo2 - Init
16.09.2017 10:42:17:LCDSysInfo2 - Error opening device
16.09.2017 10:42:17:Check Also Device FW Update: 23010288146871113357-122
16.09.2017 10:42:17:Check Also Device FW Update2: -
16.09.2017 10:42:17:Adding power mod events
16.09.2017 10:42:17:Loading GOverlay home page
16.09.2017 10:42:17:Loading charts
16.09.2017 10:42:17:GOverlay successfully inited
Kabron
Postby TheLaGmAn » Sat Sep 16, 2017 4:59 pm
Hi, i just released 1.6.2 , can you see if its fixed now?
Postby Kabron » Sat Sep 23, 2017 7:40 am
TheLaGmAn wrote:Hi, i just released 1.6.2 , can you see if its fixed now?
Absolutelly nothing changed - Black screen.
23.09.2017 10:38:19:GOverlay Started
23.09.2017 10:38:19:Version: 1.6.2
23.09.2017 10:38:19:Looking for plugins
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\APCUPS.dll
23.09.2017 10:38:19:PluginServices - Error loading plugin APCUPS, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Не удается загрузить один или более запрошенных типов. Обратитесь к свойству LoaderExceptions для получения дополнительных сведений.
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\Aquasuite.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\Aquasuite.dll: GOverlayPlugin.Aquasuite.Class1
23.09.2017 10:38:19:Plugin Name: Aquasuite for display: lcdsys
23.09.2017 10:38:19:plugin has option: xmlfile
23.09.2017 10:38:19:Looking for sensors for plugin Aquasuite
23.09.2017 10:38:19:Error loading sensors:Пустое имя пути не допускается.: в System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
23.09.2017 10:38:19:PluginServices - Error loading plugin Aquasuite, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Ссылка на объект не указывает на экземпляр объекта.
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\COH2.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\COH2.dll: GOverlayPlugin.COH2.Class1
23.09.2017 10:38:19:Coh2 - File missing: C:\Users\vlady\Documents\My Games\Company of Heroes 2\warnings.log
23.09.2017 10:38:19:Plugin Name: COH2 Plugin for display: lcdsys
23.09.2017 10:38:19:plugin has option: coh2path
23.09.2017 10:38:19:Plugin is disabled
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\DemoComplexDraw.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\DemoComplexDraw.dll: GOverlayPlugin.DemoComplexDraw.PluginClass
23.09.2017 10:38:19:Plugin Name: GOverlay Example Plugin: Complex Draw for display: lcdsys
23.09.2017 10:38:19:plugin has option: unit
23.09.2017 10:38:19:plugin has option: lineColor
23.09.2017 10:38:19:plugin has option: note
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\DemoSimpleDraw.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\DemoSimpleDraw.dll: GOverlayPlugin.DemoSimpleDraw.PluginClass
23.09.2017 10:38:19:Plugin Name: GOverlay Example Plugin: Simple Draw for display: lcdsys
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\ETS2.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\ETS2.dll: GOverlayPlugin.ETS2.Class1
23.09.2017 10:38:19:Plugin Name: Euro Truck Simulator 2 for display: lcdsys
23.09.2017 10:38:19:plugin has option: reqimages
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\HWInfo.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\HWInfo.dll: GOverlayPlugin.HWInfo.Class1
23.09.2017 10:38:19:Plugin Name: HWiNFO for display: lcdsys
23.09.2017 10:38:19:plugin has option: metric
23.09.2017 10:38:19:Looking for sensors for plugin HWiNFO
23.09.2017 10:38:19:HwInfo - Connected to hMapFile
23.09.2017 10:38:19:HwInfo -hMapFile is invalid
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\IL2COD.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\IL2COD.dll: GOverlayPlugin.ILD2COD.Class1
23.09.2017 10:38:19:Plugin Name: IL2 Cliffs of Dover (ATAG) for display: lcdsys
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\Plugin1.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\Plugin1.dll: GOverlayPlugin.Plugin1.Class1
23.09.2017 10:38:19:Plugin Name: GOverlay Example Plugin 1 for display: lcdsys
23.09.2017 10:38:19:plugin has option: timeout
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\Plugin2.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\Plugin2.dll: GOverlayPlugin.Plugin2.Class1
23.09.2017 10:38:19:Plugin Name: CrystalMark DiskInfo for display: lcdsys
23.09.2017 10:38:19:plugin has option: regkey
23.09.2017 10:38:19:Looking for sensors for plugin CrystalMark DiskInfo
23.09.2017 10:38:19:Error loading sensors, Is CristalMark running with External Applications enabled?Ссылка на объект не указывает на экземпляр объекта.: в GOverlayPlugin.Plugin2.Class1.AvailableSensors(Hashtable pluginOptions) в D:\VB\goverlay\GOverlay\GOverlay\bin\Debug\Plugins\Examples\Plugin 2\Class1.vb:строка 74
23.09.2017 10:38:19:PluginServices - Error loading plugin Plugin2, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Ссылка на объект не указывает на экземпляр объекта.
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\SensorMix.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\SensorMix.dll: GOverlayPlugin.SensorMix.Class1
23.09.2017 10:38:19:Plugin Name: Sensors Mix for display: lcdsys
23.09.2017 10:38:19:plugin has option: g4n
23.09.2017 10:38:19:plugin has option: g3s1
23.09.2017 10:38:19:plugin has option: g5s2
23.09.2017 10:38:19:plugin has option: g1s2
23.09.2017 10:38:19:plugin has option: g3s3
23.09.2017 10:38:19:plugin has option: g5s4
23.09.2017 10:38:19:plugin has option: g5n
23.09.2017 10:38:19:plugin has option: g1n
23.09.2017 10:38:19:plugin has option: g4s1
23.09.2017 10:38:19:plugin has option: g2s2
23.09.2017 10:38:19:plugin has option: g4s3
23.09.2017 10:38:19:plugin has option: g2s4
23.09.2017 10:38:19:plugin has option: g2n
23.09.2017 10:38:19:plugin has option: g1s4
23.09.2017 10:38:19:plugin has option: g5s1
23.09.2017 10:38:19:plugin has option: g1s1
23.09.2017 10:38:19:plugin has option: g3s2
23.09.2017 10:38:19:plugin has option: g5s3
23.09.2017 10:38:19:plugin has option: g1s3
23.09.2017 10:38:19:plugin has option: g3s4
23.09.2017 10:38:19:plugin has option: g3n
23.09.2017 10:38:19:plugin has option: g2s1
23.09.2017 10:38:19:plugin has option: g4s2
23.09.2017 10:38:19:plugin has option: g2s3
23.09.2017 10:38:19:plugin has option: g4s4
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\SimBin.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\SimBin.dll: GOverlayPlugin.SimBin.Class1
23.09.2017 10:38:19:Plugin Name: SimBin Car Stats for display: lcdsys
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\Slideshow.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\Slideshow.dll: GOverlayPlugin.Slideshow.Class1
23.09.2017 10:38:19:Plugin Name: Slideshow for display: lcdsys
23.09.2017 10:38:19:plugin has option: i10
23.09.2017 10:38:19:plugin has option: i2
23.09.2017 10:38:19:plugin has option: i3
23.09.2017 10:38:19:plugin has option: i4
23.09.2017 10:38:19:plugin has option: i5
23.09.2017 10:38:19:plugin has option: i6
23.09.2017 10:38:19:plugin has option: itime
23.09.2017 10:38:19:plugin has option: i8
23.09.2017 10:38:19:plugin has option: i9
23.09.2017 10:38:19:plugin has option: irandom
23.09.2017 10:38:19:plugin has option: i7
23.09.2017 10:38:19:Plugins - Checking: C:\Goverlay\Plugins\SpeedFan.dll
23.09.2017 10:38:19:Plugin found: C:\Goverlay\Plugins\SpeedFan.dll: GOverlayPlugin.SpeedFan.Class1
23.09.2017 10:38:19:Plugin Name: SpeedFan Plugin for display: lcdsys
23.09.2017 10:38:19:GOverlay is running as administrator: True
23.09.2017 10:38:19:LCDSysInfo - First init run
23.09.2017 10:38:19:LCDSysInfo - Init
23.09.2017 10:38:19:Device SS: lcdsz / lcdsz
23.09.2017 10:38:19:Device FN: Clay Logic - LCDsysinfo (GOverlay)
23.09.2017 10:38:19:LCDSysInfo - Successfully inited
23.09.2017 10:38:19:LCDSysinfo - Set brigthness to 255
23.09.2017 10:38:20:LCDSysInfo - Device Serial: 23010288146871113357
23.09.2017 10:38:20:LCDSysInfo - Device FW: 122
23.09.2017 10:38:20:LCDSysInfo2 - First init run
23.09.2017 10:38:20:LCDSysInfo2 - Init
23.09.2017 10:38:20:LCDSysInfo2 - Error opening device
23.09.2017 10:38:21:Reload settings started
23.09.2017 10:38:21:ClearSettingsMarks - Started
23.09.2017 10:38:21:Emptying all marks
23.09.2017 10:38:21:Reload settings checkpoint 1
23.09.2017 10:38:21:LCDSys Cache is Enabled
23.09.2017 10:38:21:LCDSys2 Cache is Enabled
23.09.2017 10:38:21:Reload settings checkpoint 2
23.09.2017 10:38:21:Reload settings checkpoint 3
23.09.2017 10:38:21:Reload settings checkpoint 4
23.09.2017 10:38:21:Reload settings checkpoint 5
23.09.2017 10:38:21:Reload settings checkpoint 6
23.09.2017 10:38:21:Reload settings checkpoint 7
23.09.2017 10:38:21:Loading GameProfiles
23.09.2017 10:38:21:Added profile for WG: eurotrucks2.exe
23.09.2017 10:38:21:Added profile for WG: race_steam.exe
23.09.2017 10:38:21:Added profile for WG: RelicCoH2.exe
23.09.2017 10:38:21:Added profile for WG: eurotrucks2.exe (wg)
23.09.2017 10:38:21:Added profile for WG: doomknight87_profile_2.2
23.09.2017 10:38:21:Loading OnWindowsProfiles
23.09.2017 10:38:21:Added profile for OW: default (wg)
23.09.2017 10:38:21:Added profile for OW: eurotrucks2.exe (wg)
23.09.2017 10:38:21:Added profile for OW: reliccoh2.exe (wg)
23.09.2017 10:38:21:Added profile for OW: doomknight87_profile
23.09.2017 10:38:21:Added profile for OW: doomknight87_profile_2.2
23.09.2017 10:38:21:ReloadSettings - Profile OnWindows using: Default (due to invalid profile)
23.09.2017 10:38:21:Profiles Load Ended
23.09.2017 10:38:21:Loading lcdsys2 GameProfiles
23.09.2017 10:38:21:Profiles lcdsys2 Load Ended
23.09.2017 10:38:21:Error loading some sensors: Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2' :: в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
23.09.2017 10:38:21:LCDSysinfo - Set brigthness to 100
23.09.2017 10:38:21:ReloadMarks - Started
23.09.2017 10:38:21:ReloadMarks - Error reading marks: Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2': в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
23.09.2017 10:38:21:ReloadMarks - Ended
23.09.2017 10:38:21:ReloadMarks - Error loading lcdsys2/ALL elements : Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2' : в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
23.09.2017 10:38:21:Stopping teamspeak handler
23.09.2017 10:38:21:Reload General (3d-Render) Mark: [time]
23.09.2017 10:38:21:Reload General (3d-Render) Mark: [render]
23.09.2017 10:38:21:Reload General (3d-Render) Mark: [ping]
23.09.2017 10:38:21:Reload General (3d-Render) Mark: [fps]
23.09.2017 10:38:21:Culture Type is: 1
23.09.2017 10:38:21:Reload settings end
23.09.2017 10:38:21:Color format loading
23.09.2017 10:38:21:Ping Thread Started
23.09.2017 10:38:21:Starting thread GUI
23.09.2017 10:38:21:OHMD is enabled, initing
23.09.2017 10:38:21:Starting Ticker
23.09.2017 10:38:21:Ticker thread started
23.09.2017 10:38:21:Ticker GUI thread started
23.09.2017 10:38:21:Checking for new version in method: Silent
23.09.2017 10:38:21:Req clear waiting 1
23.09.2017 10:38:22:LCDSysInfo2 - Init
23.09.2017 10:38:22:LCDSysInfo2 - Error opening device
23.09.2017 10:38:22:LCDSys - Screen clear requested and done
23.09.2017 10:38:22:DoLCDSys Exception: Ссылка на объект не указывает на экземпляр объекта.: в ab.b()
23.09.2017 10:38:23:Check Also Device FW Update: 23010288146871113357-122
23.09.2017 10:38:23:Check Also Device FW Update2: -
23.09.2017 10:38:23:Adding power mod events
23.09.2017 10:38:23:Loading GOverlay home page
23.09.2017 10:38:23:Loading charts
23.09.2017 10:38:23:GOverlay successfully inited
23.09.2017 10:39:12:Begining save
23.09.2017 10:39:12:Safe to save now
23.09.2017 10:39:12:Main config stored
23.09.2017 10:39:12:LCDSys Save Error - Элемент уже добавлен. Ключ в словаре: "doomknight87_profile_2.2" Добавляемый ключ: 'doomknight87_profile_2.2'
23.09.2017 10:39:12: в System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
в GOverlay.Form1.fc(Object A_0, EventArgs A_1)
23.09.2017 10:39:13:DoLCDSys Exception: Ссылка на объект не указывает на экземпляр объекта.: в ab.b()
23.09.2017 10:39:13:LCDSysInfo2 - Init
23.09.2017 10:39:13:LCDSysInfo2 - Error opening device
23.09.2017 10:39:14:DoLCDSys Exception: Ссылка на объект не указывает на экземпляр объекта.: в ab.b()
23.09.2017 10:39:14:LCDSysInfo2 - Init
23.09.2017 10:39:14:LCDSysInfo2 - Error opening device
Kabron
Postby TheLaGmAn » Sat Sep 23, 2017 5:53 pm
can you send me an email to support@goverlay.com so we can take a look?
