Backup Profile?
Backup Profile?
Postby stadtpirat » Sun Jun 22, 2014 9:46 pm
i make a nice Profile for Windows.
How can i backup it?
stadtpirat
Re: Backup Profile?
Postby TheLaGmAn » Sun Jun 22, 2014 9:48 pm
check our faq here
http://www.goverlay.com/content/faq/
on how to backup a profile, be careful when using the registry editor.
Re: Backup Profile?
Postby stadtpirat » Mon Jun 23, 2014 5:32 pm
Hi, thanks for the help. :shock:
Fine... but to search and safe the registry is too heavey at every change
I write a little Batch to safe my profile and Settings.
Safe as .bat and Run as Admin
@echo off
REG EXPORT "HKCU\Software\VB and VBA Program Settings\rtss_window" C:\goverlay.reg
stadtpirat
Re: Backup Profile?
Postby TheLaGmAn » Mon Jun 23, 2014 7:50 pm
Thanks for the bat file, i will probably tweak it a little and maybe add an option in goverlay to do the backup in the next version till i do the proper import/export feature
Re: Backup Profile?
Postby stadtpirat » Mon Jun 23, 2014 10:52 pm
Wow Thanks for Export end Import.
Update: Filename now with date and time from Backup :-)
@echo off
set /a stunde=%time:~0,1%
if !stunde! lss 0 (
set /a stunde=0
set /a stunde=%time:~1,1%
echo 1
) else (
set /a stunde=%time:~0,2%
echo 2
set minute=%time:~3,2%
set sekunde=%time:~6,2%
REG EXPORT "HKCU\Software\VB and VBA Program Settings\rtss_window" C:\goverlay-%date%-%stunde%_%minute%_%sekunde%.reg
stadtpirat
Re: Backup Profile?
Postby TheLaGmAn » Mon Oct 13, 2014 11:09 pm
Import and Export for profiles done.
Use the latest BETA
viewtopic.php?f=3&t=54
