Another way to install driver in Windows 10
Postby Kabron » Tue Apr 11, 2017 12:25 pm
The technique, suggested here did not bring me success, althougth, drivers signing is always off in my PC.
Here is another one:
1. Download and run zadig.exe from http://zadig.akeo.ie/.
2. Find LCDsysinfo (GOverlay) in devices field. If nothing there, use Options->List All Devices
3. Choose libusbK (v3.0.7.0) driver and install it.
If you won't, here is driver archive https://yadi.sk/d/JD4y8YMz3Grt29.
Kabron
Re: Another way to install driver in Windows 10
Postby TheLaGmAn » Tue Apr 11, 2017 2:15 pm
Thats odd, i installed it in several windows 10's.
Anyhow, thanks for the alternative solution
Users browsing this forum: No registered users and 29 guests
