GOVerlay crashes after several hours of use [FIXED]
Postby enderep12 » Fri Mar 24, 2017 6:45 pm
After several hours of use, GOverlay just crashes (LCDSysinfo goes into energy saving mode) and this window pops up: http://imgur.com/a/Ks5A7
Is there a way to disable these VR Charts to prevent the crash? I have everything VR related disabled in my config.
As long as the above mentioned window is open a restart of GOverlay doesn't do anything. I have to close the window and only then can I restart GOverlay to restore LCDSysinfo functionality.
My log is full of VisualBasic errors regarding converting string to double, not sure if this is related. All sensors work as intended.
24.03.2017 19:45:05:LCDSys - Sensor error:  38
24.03.2017 19:45:05:LCDSys - Sensor 1365543861.32573 (CPUInfoBox Fan_Sensor malfunction : Ungültige Konvertierung von der Zeichenfolge  in Typ Double. / Debug value: 38 :    bei Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
   bei Microsoft.VisualBasic.CompilerServices.Operators.CompareObject2(Object Left, Object Right, Boolean TextCompare)
   bei Microsoft.VisualBasic.CompilerServices.Operators.CompareObjectNotEqual(Object Left, Object Right, Boolean TextCompare)
   bei aa.b()
enderep12
Re: GOVerlay crashes after several hours of use
Postby TheLaGmAn » Fri Mar 24, 2017 7:04 pm
Which version of GOverlay are you running?
Postby enderep12 » Fri Mar 24, 2017 7:34 pm
Newest one, 1.5.2 but this occurs since 1.4.8.
enderep12
Postby TheLaGmAn » Fri Mar 24, 2017 7:47 pm
could you send me an email to support@goverlay.com about this so we can check it out in more detail?
Postby Woyta » Sun Apr 23, 2017 6:36 pm
I would say that is memory leak as was sorted there. viewtopic.php?f=2&t=251
I got problem with leak since 1.46. Last version working correctly was 1.42 i think.
This is fresh Win 7 x64 Instal with updates and latest 1.52. Clean configuration.
As you can see goverlay eats up memory bit by bit until it crashes about 1,5gb of ram.
Woyta
Postby TheLaGmAn » Sun Apr 23, 2017 7:27 pm
Woyta wrote:I would say that is memory leak as was sorted there. viewtopic.php?f=2&t=251
Could you contact me to support@goverlay.com so we can chck this out? Im not able to reproduce it yet
Postby Woyta » Tue May 02, 2017 11:09 pm
After week of using beta 1.5.3.4 i have to say that i have no problems on my primary PC.
Woyta
