Top Process sensor sometimes does not work
Re: Top Process sensor sometimes does not work
Postby DooMknight87 » Wed Feb 15, 2017 7:43 pm
After doing all the steps carefully, I rebooted and now the sensor get stuck on 0, and the log show this message:
15/02/2017 20:33:53:   en u.b()
15/02/2017 20:33:53:LCDSys - Sensor 1413234237,2667 (SensorBarGraph: Bar Graph malfunction : Referencia a objeto no establecida como instancia de un objeto.
15/02/2017 20:33:53:LCDSys - Sensor 1413233981,91002 (SensorBarGraph: Bar Graph malfunction : Referencia a objeto no establecida como instancia de un objeto.
15/02/2017 20:33:52:Plot Graph inited with bg color:800
15/02/2017 20:33:52:Plot Graph inited with bg color:34816
15/02/2017 20:33:51:   en u.b()
15/02/2017 20:33:51:LCDSys - Sensor 1413234237,2667 (SensorBarGraph: Bar Graph malfunction : Referencia a objeto no establecida como instancia de un objeto.
15/02/2017 20:33:51:LCDSys - Sensor 1413233981,91002 (SensorBarGraph: Bar Graph malfunction : Referencia a objeto no establecida como instancia de un objeto.
15/02/2017 20:33:51:LCDSys - Screen clear requested and done
15/02/2017 20:33:51:OHMD inited
15/02/2017 20:33:50:Req clear waiting 1
15/02/2017 20:33:50:Load error: Devuelto error HRESULT E_FAIL de una llamada a un componente COM. ::    en System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   en System.Management.ManagementObject.Initialize(Boolean getObject)
   en System.Management.ManagementBaseObject.get_ClassName()
   en System.Management.ManagementClass.GetInstances(EnumerationOptions options)
   en System.Management.ManagementClass.GetInstances()
   en GOverlay.Form1.a(String A_0)
   en GOverlay.Form1.Form1_Load(Object sender, EventArgs e)
DooMknight87
Postby TheLaGmAn » Wed Feb 15, 2017 8:05 pm
check if the poweshell command works
Postby DooMknight87 » Wed Feb 15, 2017 8:35 pm
The powershell command works, but the sensor still in 0
DooMknight87
Postby Gizmo1203 » Mon Aug 27, 2018 1:10 pm
I have also problems with the Top Process sensor information. It only displays "Idle)\Prozessor", even though the powershell command works fine. Any ideas?
That's the log message:
06.09.2018 18:12:54:ProcessWatch - Resetting Watcher "\Prozess(*)\Prozessorzeit (%)" -si 1
06.09.2018 18:12:51:ProcessWatch - Resetting Watcher "\Prozess(*)\Prozessorzeit (%)" -si 1
06.09.2018 18:12:38:ProcessWatch - Not reciving proper data, restarting watcher in 10 seconds. Run in CMD "lodctr /R" to fix it
06.09.2018 18:12:38:ProcessWatch - Resetting Watcher "\Prozess(*)\Prozessorzeit (%)" -si 1
Prozess=process
Prozessorzeit=process time
Gizmo1203
Postby TheLaGmAn » Fri Sep 21, 2018 3:50 pm
Try with the BETA 1.6.4.11_cgu and check what it says in the logs after startup on the line
"ProcessWatch - Starts with parameters:"
then run typeperf with those parameters on powershell and post the output
Postby Gizmo1203 » Fri Sep 28, 2018 10:03 pm
TheLaGmAn wrote:Try with the BETA 1.6.4.11_cgu and check what it says in the logs after startup on the line
I sent it to you in a PM..
Gizmo1203
