Case around LCD screen wider on right side?
Postby nbtc971 » Thu Feb 02, 2017 3:56 am
Just got my GOverlay but something is weird, the casing around the LCD screen is wider on the right side than the left. I haven't found any other pictures that look like this? Anyone else get one like this?
nbtc971
Re: Case around LCD screen wider on right side?
Postby ZeZerT » Thu Feb 02, 2017 4:34 am
I have that too, I must say I didn't notice until now
I don't find it very disturbing, my room being quite dark I only see the display and not it's borders
ZeZerT
Postby TheLaGmAn » Thu Feb 02, 2017 1:04 pm
The units i have are from the old case, i will check with the manufacturer to see if this is normal or not
Postby nbtc971 » Fri Feb 03, 2017 1:28 am
Not a huge fan of that... seems sloppy.
nbtc971
Postby SubSonix » Fri Feb 03, 2017 12:03 pm
That really doesn't look great. But still better than my (I assume original) model as It's just some bent black perspex :P
*EDIT* Just looked at the Ebay listing for the new case and the image there looks just like what you received...
SubSonix
Postby TheLaGmAn » Fri Feb 03, 2017 3:20 pm
Yes, i checked with the manufacturer and that version is correct, its bigger on one side, due to the design of board behind.
I will see if i can request some modification on that matter.
