problem after windows update.
Postby tyf » Sat Jan 21, 2017 9:37 am
Hello to all.
i have make a screen with upload images that i have make.
after a windows 10 update it have stop working.
i erase all trying to start it again with simple screen and it always says
object refference not set to instance or a objet.
even with nothing on the configurator or just one (lets say cpu info box) without setting any sensor.
i use it with open hardware monitor.
also i have give to a friend the same setup for the screen ( we have same motherboard and cpu) can i retrive the setup config and the images that i have make from his folder?
tyf
Re: problem after windows update.
Postby TheLaGmAn » Sat Jan 21, 2017 4:05 pm
Hi, can you please provide the log.txt file in the GOverlay folder?
Thanks.
Postby tyf » Sun Jan 22, 2017 12:24 pm
thanks for the reply.
can you just tell me how to uninstall it?
i will re install it from the start.
i just delete the registry entries?
all the file?
tyf
Postby tyf » Sun Jan 22, 2017 1:03 pm
ok i juste deleted all the rtss reg entry and it work. i will fix the config from the start.
also can i update my screen. i think is from the first ones and you have a firmware upgrade.
is that possible?
thanks for the responces!!
tyf
Postby tyf » Sun Jan 22, 2017 2:57 pm
everything ok.
i re applied the old config.
again i see the error.
i deleted all sensors tha gave the error and fix it from the start.
all ok again.
tyf
