VR Mode
VR Mode
Postby TheLaGmAn » Wed Jan 11, 2017 6:01 pm
GOverlay now supports VR mode to use the desktop and see the GOverlay charts
Here is a video of how it works:
https://www.youtube.com/watch?v=S2s0mniK45o
Features are:
1) Built in Goverlay VR Desktop in the dashboard: This works almost the same as the built in SteamVR desktop BUT only displays ONE monitor (the first one), so if you have multiple monitors now you can use your desktop properly, it also features the SteamVR keyboard and you can change the zoom size.
2) Goverlay Charts in Dashboard: You can see the sensors you defined in GOverlay in a chart graph in VR, you can add FPS and temperatures to monitor your VR stats.
3) Goverlay Charts in-game: You can bring up the Goverlay chart graph while you are playing as an overlay, so you dont need to go back to the dashboard. You can configure a button and the amount of times you need to press it to show the overlay. You can also set the distance the graph displays from the hand you spawned the chart.
Re: VR Mode
Postby Elric8/2 » Thu Oct 15, 2020 10:11 am
Hi
How do i get rid of the "goverlay vr chat" popping in the middle of my vr games? could nof find how to and it's very annoying
Elric8/2
Re: VR Mode
Postby TheLaGmAn » Thu Oct 15, 2020 1:17 pm
What do you mean VR chat? the chart?
if you want to disable, just go to Configuration > Options > VR and set to disable
Re: VR Mode
Postby Elric8/2 » Thu Oct 15, 2020 1:33 pm
yes chart .
Thanks !
Elric8/2
Users browsing this forum: Majestic-12 [Bot] and 14 guests
