Error Message all the time
Postby m31asy » Sat Sep 23, 2023 3:21 pm
Hello, i got the LCDSysInfo 2 3,5" today, and installed the latest driver and Goverlay 1.6.9.19
When i start the Wizard i get a very long error message and Goverlay shuts down, Goverlay found an unhandled error, message is: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt, bei GOverlay. Wizzard. OK_Button_ClickObject sender. EventArgs.....
When i press the Save and Apply button i get annother Message which tells: error while saving elements, please try again. Error is: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. (sorry for my poor translation since i use the german release)
I would post screenshots if i would know how.
Windows 11 Pro
13900k
Zotac 3090 Trinity
Corsair Vengeance 2 x 32Gb 6600 Mhz CL32
MSI Z790 Ace
Aquasuite x.75
Hope anyone can help.
Thank you for your troubles
sincerly
m31asy
m31asy
Re: Error Message all the time
Postby TheLaGmAn » Wed Sep 27, 2023 5:20 pm
can you contact me at support@goverlay.com so we can take a look at whats going on there?
Postby m31asy » Wed Oct 04, 2023 10:51 am
After an Online Session with Admin TheLaGmAn he found a way to fix my problem.
Many thanks at this point.
After deleting all not used profiles the failure didnt showed up again.
Maybe this will help someone who has the same problem.
m31asy
Users browsing this forum: No registered users and 37 guests
