Own BMP files
Own BMP files
Postby xneo70 » Fri Oct 15, 2021 5:51 pm
Is there somewhere a guide on how i can progrann the display?
Because is i use downloaded profiles, and if i see a ICON pad, it contains own bmp's that has to be uploaded to the display device.
If i use a new empty profile, i cannot set my own bmp files. So how can i do this?
xneo70
Re: Own BMP files
Postby TheLaGmAn » Fri Oct 15, 2021 6:53 pm
You need to upload the icon to the device.
If you are on 3.5'', go to Upload, "Select files to upload", pick the file, hit upload and then you can use it on the device
Re: Own BMP files
Postby xneo70 » Sat Oct 16, 2021 10:48 am
Thanks.
Do you know what type of immages are supported?
And what is with "image depending on sensor" which type of immages does this support?
xneo70
Re: Own BMP files
Postby TheLaGmAn » Mon Nov 08, 2021 9:58 pm
we only support BMP images, and " image depending on sensor", what it does, is to be able to pick different images for different static values of a sensor
