My display had some bad lines.
Can something be done to fix it?
CybaGirl wrote:Was it working before without issue?
IF so. Could be a loose cable to the LCD panel inside?
Wagx wrote:
it was suddenly.
Could it be the ribbon cable?
CybaGirl wrote:Wagx wrote:
it was suddenly.
Yes I am thinking it is the ribbion cable that has come loose and needs reseating and or the connection needs cleaning.
the soldering is horrible
/quote]
Yes that doesn't look the best and looks like a rushed job. Are you confident in fixing it yourself?
You only need to heat up what is there with a soldering iron to make it neater and let it cool.
There are a ton of videos on YouTube you can check out if you are not sure.
Hope you get it sorted.
Wagx wrote:
I did the repair and everything resolved.
returned to normal, as expected.
Conclusion: I had the misfortune of having a product that was poorly assembled(*).
Now everything is working again.
*one screw is missing next to the micro usb, i put a new one but to my surprise this screw makes the usb not fit in the cut of the plastic box, so it is necessary to leave without.
Users browsing this forum: No registered users and 20 guests
