LCDSysInfo 3.5 stand missing?
Postby SubSonix » Sat Aug 14, 2021 10:48 am
Hi, I've just got a question;
I bought a 3.5" model and it says it comes with a stand "Adjustable stand allows for different angles" but I didn't receive one.
I've already talked to coldtears and they said it doesn't come with one. Just wondering if this is correct or not?
SubSonix
Re: LCDSysInfo 3.5 stand missing?
Postby SubSonix » Sat Aug 21, 2021 2:21 am
Bump as I updated the title for visibility.
SubSonix
Postby TheLaGmAn » Mon Aug 23, 2021 1:58 pm
as far as i know, the "stand" is just a sticky metal piece in the back, like a ring, to be able to keep the display standing, and if you move it a bit upwards, the display sits more looking at the sky, so thats the way you change the angle
Postby SubSonix » Mon Aug 23, 2021 2:05 pm
Ah, well I didn't receive that. No worries though, I've already ordered a cheap stand off ebay lol
SubSonix
Users browsing this forum: No registered users and 10 guests
