Dead Pixels?
Dead Pixels?
Postby nikkdizzle » Sat Jul 24, 2021 7:55 am
So I was rearranging things in my case and I moved my GOverlay on the otherside of my case and thus needed to flip my display. I used the 180flip in the software, and it instructed me to unplug device to reboot it.
I did so and when it started back up I have now lines of dead/stuck pixels.
Just wondering if this happened to anyone else, or if anyone knows a fix to get it right.
nikkdizzle
Re: Dead Pixels?
Postby TheLaGmAn » Sun Jul 25, 2021 8:59 pm
did you upgraded the firmware or it was already on a version supporting the flip feature?
If you fip it back to what it was (software) it still does the same issue?
Re: Dead Pixels?
Postby nikkdizzle » Fri Jul 30, 2021 12:02 am
it a version that supports the feature.
as I have flipped it before hand with no issue.
Tried flipping it back and the line persists in the same spot.
nikkdizzle
Re: Dead Pixels?
Postby TheLaGmAn » Fri Jul 30, 2021 1:46 am
can you try with a profile with a single text in the middle of the screen and white background?
Re: Dead Pixels?
Postby nikkdizzle » Fri Jul 30, 2021 2:30 am
here is a test profile in both orientations.
nikkdizzle
Re: Dead Pixels?
Postby TheLaGmAn » Mon Aug 02, 2021 5:45 pm
okay, you will need to contact the manufacturer to see if he has some ideas regarding this issue since its not software related, contact him at coldtearselectronics@gmail.com
Users browsing this forum: Google [Bot] and 12 guests
