Need help!!!
Need help!!!
Postby viktor048 » Thu Jun 17, 2021 10:46 am
Hey! I really need help !! Yesterday I turned on the computer, and the picture is not displayed on the LCDSysInfo screen, as expected, the readings of the sensors are blinking (when the readings change). Before that, everything was fine. I tried it on another computer - the same thing. I tried to put the beta version - it did not help. As I understood from the FAQ - you do not need to update the firmware. Tell me what you can do. Video attached
viktor048
Same error here...
Postby nickbeat76 » Thu Jun 17, 2021 6:22 pm
I have the same problem... :?
Installed latest Win10 Updates, after the reboot LCDSysInfo only displays a black screen with the "Energy saving mode" on the bottom.
But changes of the readouts shortly flash on the screen, then disappear.
Updated GOverlay to V1.6.9.19, no change...
Updated the FW from 231 tu 241, no change...
Reinstallation of GOverlay, no change...
Different USB-Ports, no change...
Maybe some changes in Win10 after the update?
nickbeat76
Re: Need help!!!
Postby TheLaGmAn » Fri Jun 18, 2021 7:37 pm
what windows 10 version you both have?
Re: Need help!!!
Postby nickbeat76 » Fri Jun 18, 2021 9:09 pm
Windows 10 Home
Version 21H1 (Build 19043.1055)
nickbeat76
Re: Need help!!!
Postby viktor048 » Tue Jun 22, 2021 4:30 pm
Windows 10 Pro
Version 21H1
19043.1055
viktor048
Re: Need help!!!
Postby nickbeat76 » Sun Jul 25, 2021 7:12 pm
Any fix?
nickbeat76
Re: Need help!!!
Postby TheLaGmAn » Sun Jul 25, 2021 9:01 pm
couldnt find anything software related, please contact the manufacturer at coldtearselectronics@gmail.com to see if he has some insight in this two cases, its not common
Users browsing this forum: No registered users and 14 guests
