hwinfo plugin shows only 1 GPU
Postby theanalyzer » Sat Jun 05, 2021 5:31 am
Hi All,
I have two GPUs in my system and want to keep an eye on metrics of both GPUs. GPU0 sensor data is not showing though, only GPU1. Both sensor data show in the hwinfo sensors page.
2x RTX 3080s if it helps.
How do I fix this?
hwinfo 7.04
hwinfo plugin from forum
Goverlay v1.6.9.5
theanalyzer
Re: hwinfo plugin shows only 1 GPU
Postby TheLaGmAn » Sun Jun 06, 2021 2:57 pm
does the embeed sensors (openhardwaremonitor dll and librehardwaremonitor dll) have both gpus?
Postby theanalyzer » Fri Jun 11, 2021 9:18 pm
TheLaGmAn wrote:does the embeed sensors (openhardwaremonitor dll and librehardwaremonitor dll) have both gpus?
sorry for the late reply, yes, but they are limited in what stats they show.
i am looking for power usage and memory (junction) temperatures which hwinfo reports
theanalyzer
