after a hard fight with display
Re: after a hard fight with display
Postby carmyyy » Thu Apr 08, 2021 2:40 pm
TheLaGmAn wrote:okay, im confused regarding if 245 is working properly or not.
please continue this issue with coldtearselectronics@gmail.com since hes the one that can provide a differernt firmware if needed
i have only 242ips version but its not working
carmyyy
Postby Fatherbull » Thu Apr 08, 2021 3:27 pm
Moinsen,
Ich habe eben auf die FW 245 upgedatet. Lief ohne Fehler durch. Nach dem Reboot ist aber nur noch ein Drittel des Displays sichtbar. Hat jemand eine Idee?
Gruß
Bull
Fatherbull
Postby TheLaGmAn » Thu Apr 08, 2021 3:49 pm
are you sure you used the correct source firmware? you cant just use any firmware version, you need one that follows your device fw path.
I see you requested 231>241 and 235>245
which one was your original firmware?
