after a hard fight with display
Postby carmyyy » Mon Mar 29, 2021 4:23 pm
Good day people,
have ordered the IPS panel for 40 euro.
Unfortunately, it has then lasted only 1 month.
The Device was working perfect.
So contacted the support Cold-Electronics.
Had to bridge the device , flash with ---> 245 and its working.
Now the device works again, but the colors are shit.
i can not change the right color .... is the display broken ??.
if i pick the black color on the device its white.... i pick white its black.
hes anyone this before ?
i need help please
greetings from germany
crap qual
right
Flashing
carmyyy
Re: after a hard fight with display
Postby JohnnyBlack » Mon Mar 29, 2021 6:24 pm
Grüße aus Berlin :D
I tried to flash my broken device with FW 241 and my display showed the same behaviour. After that I flashed FW 242. The colors are now the same as I've set.
JohnnyBlack
Postby carmyyy » Mon Mar 29, 2021 6:40 pm
habe es gerade auch anders geflasht... nun ist es wieder schwarz
carmyyy
JohnnyBlack wrote:Grüße aus Berlin :D
echt nervig..
carmyyy
Postby JohnnyBlack » Mon Mar 29, 2021 6:53 pm
verdammt. Hast du mal alle FW Versionen durchprobiert, die es so gibt? Eine davon muss ja funktionieren.
JohnnyBlack
Postby carmyyy » Mon Mar 29, 2021 8:00 pm
JohnnyBlack wrote:verdammt. Hast du mal alle FW Versionen durchprobiert, die es so gibt? Eine davon muss ja funktionieren.
hab ich kann nicht mehr zurück patchen auf 245.....
carmyyy
Postby TheLaGmAn » Mon Mar 29, 2021 9:25 pm
what was your original firmware version?
and what version of goverlay are you running?
Postby carmyyy » Tue Mar 30, 2021 2:41 pm
TheLaGmAn wrote:what was your original firmware version?
support send me fimeware 245 its working but the colors not.
So i need 245IPS ? Fimeware the 242IPS its not working...
carmyyy
Postby carmyyy » Tue Mar 30, 2021 3:21 pm
i testet all version but only the 245 its working. i need ips version
carmyyy
Postby TheLaGmAn » Wed Mar 31, 2021 5:19 pm
okay, im confused regarding if 245 is working properly or not.
please continue this issue with coldtearselectronics@gmail.com since hes the one that can provide a differernt firmware if needed
