LCDsysinfo 3,5'' weird connection issue
Postby JohnnyBlack » Sun Mar 28, 2021 10:29 am
Hello everyone,
Foreword: The LCDSysinfo 3.5-device is directly connected to the motherboard via USB 9-pin to micro-USB. The device worked without problem. GOverlay version is v1.6.9.
since I unplugged my PC from power, my LCDSysinfo 3,5'' has a strange behaviour. After start of GOverlay the device reconnects several times, but it doesn't shows any profile. The only thing it shows is "LCDsysinfo for GOverlay 2.0 run GOverlay for configuration". When I open GOverlay in the status tab it says LCDSysinfo 3,5 is enabled and detected but in the LCDSysinfo 3,5'' > Upload tab it says the memory is empty.
In LCDSysinfor 3,5'' > Tools is the serial number 0000000 and FW 0.
The log tab says, there a several things (fonts, etc.) missing.
what I have done so far:
I tried to restore default files over the Wizard tab. It seems GOverlay upload something successful and after that the memory seems to contain data. But after reconnect the memory is empty again.
I reinstalled the driver as described in the FAQ. The device is listed in the device manager. I also executed the GOverlay Tester. It seems the driver is installed correctly (report.txt is attached).
I also tried several USB ports (no hub ports) and another PC - same behaviour.
I did not upgraded the FW.
report.txt
(2.27 KiB) Downloaded 406 times
can you please help me?
EDIT: When the device is connected and GOverlay isn't started, the device doesn't reconnect. Only when GOverlay is started, the device stuck in a reconnect loop.
JohnnyBlack
Re: LCDsysinfo 3,5'' weird connection issue
Postby TheLaGmAn » Mon Mar 29, 2021 1:40 pm
can you try with different usb external cables?
Postby JohnnyBlack » Mon Mar 29, 2021 5:28 pm
Thanks for your answer. I already tried two USB A to micro USB cable. I also changed USB ports and tried USB 2.0, USB 3.0, front USB and the second 9-pin USB on the mainboard. Same behaviour.
JohnnyBlack
Postby JohnnyBlack » Mon Mar 29, 2021 6:21 pm
UPDATE: DO THIS ON YOUR OWN RISK! IT COULD BRICK YOUR DEVICE!
I flashed a new FW to the device according to the instruction of this post:
https://www.goverlay.com/forum/viewtopic.php?f=2&t=1729
First I tried FW 241, but the behaviour was the same described in this post (the colors are negatives to the configured colors). So i flashed the FW version 242 and it works! Seems the FW on my device was corrupted.
Thank you for your help anyway!
JohnnyBlack
Postby carmyyy » Tue Mar 30, 2021 2:52 pm
JohnnyBlack wrote:UPDATE: DO THIS ON YOUR OWN RISK! IT COULD BRICK YOUR DEVICE!
i have the 242 ips fimeware but my display stay black... after i patch that. i can patch run the device only with 245..
carmyyy
