saving VisualScript
saving VisualScript
Postby JaxyL_597 » Sat Mar 27, 2021 3:54 am
Hi all, I have designed some Visual Scripts, and they are working fine but when I close the app and re-open they are "semi-vanished"...
What I mean for "semi-vanished"? They are not working on lcd, not displayed with the pinkish bar but if I click on VS button on their sensor, the script is there! I can simply save and they work, but I don't want to activate them manually every time. This happens on every VS on every profile when I start the app, I tried to export and import the VS but nothing changes, I didn't found a dedicated directory to store them.
Log tells me this:
27/03/2021 04:41:32:Error loading VisualScripting data for 1496830085,18818_sensor_id : Tentativo di deserializzare un flusso vuoto. :: in System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
in System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream)
in GOverlay.Form1.ReloadSettings(Object lcd)
Can someone please help me? Thanks!!
version 1.6.9 firmware 242
JaxyL_597
Re: saving VisualScript
Postby TheLaGmAn » Mon Mar 29, 2021 7:54 pm
can you try the latest beta first?
if it still happens, we can take a look
Postby JaxyL_597 » Wed Mar 31, 2021 9:34 am
Updated to 1.6.9.13 but nothing changes :(
Tell me if you need something for future research, but if I am the only one with this issue don't mind, I found another profile I'm happy with :D
JaxyL_597
Postby TheLaGmAn » Wed Mar 31, 2021 5:40 pm
try viewtopic.php?f=3&t=1734
it will most likely have the same issue but provide the log file after you start goverlay and get that error.
Also, are you running goverlay as admin?
are you using a custom shortcut to run it? if so, whats the working path for the shortcut?
Postby JaxyL_597 » Wed Mar 31, 2021 9:55 pm
Updated and in fact the issue is still there.
Yes, I run Goverlay as admin; I'm not 100% sure of what you mean but I didn't made any modification to the shortcut.
log.txt
(2.23 MiB) Downloaded 398 times
JaxyL_597
Postby TheLaGmAn » Thu Apr 01, 2021 8:59 pm
can you see if you have this file
C:\Program Files (x86)\GOverlay\temp.govVS
and if so, paste its contents
Postby JaxyL_597 » Thu Apr 01, 2021 10:26 pm
I have it but is 0kb, after a fresh start and a "save and apply" to the profile with VS not visualized
JaxyL_597
Postby TheLaGmAn » Thu Apr 01, 2021 11:28 pm
okay, try
and see if there is any difference, post the log file as well
Postby JaxyL_597 » Fri Apr 02, 2021 12:56 pm
Updated, no changes: VS in still inactive, file temp.govVS is still 0kb
log.txt
(1.3 MiB) Downloaded 370 times
JaxyL_597
Postby TheLaGmAn » Fri Apr 02, 2021 2:22 pm
okay, i might of found the issue
try
if it still doesnt work, post the log again
