Setting for the wattage
Postby webfreak75 » Thu Mar 25, 2021 6:57 pm
Hello Community,
I use Goverlay in conjunction with AIDA64 and Riva tuner.
I downloaded a theme from the forum and adapted it to my purposes.
Unfortunately, I can not find a setting under the sensor values to read the wattage consumption of the CPU and GPU.
Does anyone know advice?
webfreak75
Re: Setting for the wattage
Postby TheLaGmAn » Fri Mar 26, 2021 3:36 pm
do you have those values on AIDA64? if so, to see them on goverlay first enable them on AIDA64 in settings > preferences > external applications and mark the sensor you want
Postby webfreak75 » Fri Mar 26, 2021 5:49 pm
That's the problem, I have activated all sensor values, but then I can't find any in the sensor settings of Goverlay that indicate the wattage.
webfreak75
Postby TheLaGmAn » Sat Mar 27, 2021 2:26 pm
whats the sensor aida has with your watts?
can you show a screen of the aida64 setting with those enabled to see them?
