Reresh bug when number of digits decreases
Postby mm1985 » Sat Feb 20, 2021 4:22 pm
I just recieved de LCDSysInfo 3.5. I am using GOverlay 1.6.9 and using AIDA64 for the sensors. The five numbers at the bottom row are my case fan speeds.
But when I set my fan speeds around 500 RPM I see this:
The correct should be 545, 508, 497, 521 and 520. So basically the last digit are not cleared while it should be. Those digits will be cleared when I click on Save and Apply in Profiles section in the GOverlay software.
How can I solve this issue?
One workaround is to set the number of digints to 4 and use zero's to fill. But those zero's I find ugly.
mm1985
Re: Reresh bug when number of digits decreases
Postby mm1985 » Sun Feb 21, 2021 1:57 pm
It seems that this bug is related with the font "Regular Font". When I for example choose one of the Arial fonts I can not reproduce this issue.
Actually with "Regular Font" the option Font Alignment also doesnt do anything. It will always be alligned Left
So I have now solve this issue by selecting the font 'Arial 30px' which is fine for me.
mm1985
