Turning off display in energy saving mode
Postby moosew168 » Tue Feb 09, 2021 3:29 pm
Hi there!
I just started with the GOverlay and already love it :)
What came to my mind: Is there any possiblity to turn off the display when it's in energy saving mode?
My USB ports are still powered on when the PC is shut down. This way the display goes into energy saving mode and glows without any content.
Anything I can configure differently? Or is this something for a firmware update?
Thanks!
moosew168
Re: Turning off display in energy saving mode
Postby TheLaGmAn » Tue Feb 09, 2021 3:32 pm
the display cant be turned off but can dim its brightness, have you tuned down the brightness when idle option?
in lcdsysinfo 3.5 > settings > brightness when idle, set it to zero, you will need to restart the lcdsysinfo device (power off/on)
Postby MichalHrbek » Thu Apr 15, 2021 4:11 am
Hello. It does not work for me. is there a solution?
MichalHrbek
Postby TheLaGmAn » Thu Apr 15, 2021 8:42 pm
what does not work? the display will dim to the brightness set but never turn off unless your motherboard cuts usb power
